-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Will FCP import a targa sequence? (https://www.dvinfo.net/forum/final-cut-suite/54876-will-fcp-import-targa-sequence.html)
George Odell November 23rd, 2005 10:24 AM
Hello to all:
I'm not a Final Cut Pro user as such but I need to prepare some material for a client who is. I have two questions:
1) Will FCP import a targa sequence and work with it on the timeline along with existing HD material?
2) Does FCP work with all HD resolutions (1920 X 1080I, 1280 x 720P)?
George
Tim Dashwood November 23rd, 2005 02:17 PM
Yes... in a roundabout way. Use Quicktime Player Pro (the "pro" registration # ships with FCP to unlock "pro" functionality) and "open image sequence." Then just save as a Quicktime file. The original uncompressed TIFF quality is retained. You can even save it "dependent" on the original TIFF files so that no additional hard drive space is required.
Yes. FCP is completely resolution independent. You simply set your sequence resolution/codec to whatever is needed.
George Odell November 23rd, 2005 02:58 PM
Thanks, Tim, for the detailed reply.
Question for you... do you think using a targa sequence is a viable way to distribute a video clip "cross platform" like this?
Just wondering.
George
Dave Perry November 23rd, 2005 04:36 PM
Yes George. We do it all the time.
