-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   4:3 to 16:9 Help (https://www.dvinfo.net/forum/final-cut-suite/59402-4-3-16-9-help.html)
Carlos Parra January 29th, 2006 09:11 PM
4:3 to 16:9 Help
Ok -- I shot an independent film on a Canon GL1, I used the 16:9 GL1 option (it stretches the height). I accidentally imported the film in 4:3 ratio to Final Cut Express HD. By the time I noticed my mistake, I had imported the entire film. I changed the easy setup to 16:3, hoping it would change the format and it did. When I'm editing, the viewer and canvas show the film in widescreen format. But when I export the file to QuickTime, the film is back to its 4:3 format. Does anyone know if I can change the stretched 4:3 to 16:9 with out having to re-import the film from the camera and DV tapes?
Nate Schmidt January 30th, 2006 01:14 AM
Carlos, do a search of this forum for 16:9 it's explained better than I can do right now.
Dave Perry January 30th, 2006 06:08 AM
Carlos,
This the correct format. All DV is 720x480 whether it's 16:9 or 4:3. If you are delivering the end product as a DVD, then you set the aspect ratio in your DVD authoring program.
Carlos Parra January 30th, 2006 01:31 PM
Originally Posted by Dave Perry
Carlos,
Thanks! :D
