FCP5 Audio Sync Issues
Ok heres were Im at...
I have footage shot in 24pA from a DVX and an XL2. Footage looks great played from camera..no problem. Im going into FCP5, settings are as follows.. Capture Setting: DV NTSC 48 Khz Advanced (2:3:3:2) Pulldown Removal Sequence Settings: DV NTSC 48 Khz 23.98 Everything goes in fine but the audio from both cameras is off. It seems to vary from clip to clip how off it is. Iv tried offseting the audio, the dvx audio sync tool..nothing seems to work. I am monitoring out through firewire and am listeing through audio the same. Does it have to do with the pulldown settings? I am completly lost. Any help would be greatly needed. |
See if this article helps you out at all http://larryjordan.biz/articles/lj_dvx_capture.html
| All times are GMT -6. The time now is 06:21 PM. |
