-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Plug in for Pan and Scan? (https://www.dvinfo.net/forum/final-cut-suite/77084-plug-pan-scan.html)
Harry Bromley-Davenport October 8th, 2006 02:55 PM
Does anyone know of a plugin that will make pan and scan easier? I have to pan and scan a 16x9 HD project down to 4x3 and am having a bad time coming up with a good workflow.
Any ideas/suggestions welcome.
Many thanks
Harry
Gunleik Groven October 9th, 2006 04:41 AM
OK. I may be off here, but do you basically need to do an anamorphic (non-cropped) SD timeline, or do yoiu want to make a pan&scan DVD?
As for alt 1:
Drop your finished HD timeline into an SD anamorphic timeline of the right kind - be it uncompressed or DV.
This would be the thing to do if you're going for a tape out (digi/mini DV or whatever)
As for alt 2
Finish your show in HD. Make a reference movie and drop it on compressor.
The pan/scan and (or) letterbox setup is in DVD studio pro.
Gunleik
Harry Bromley-Davenport October 9th, 2006 01:06 PM
I want to be able to pan across the 16x9 area with a 4x3 frame size. That is to say, adjusting the position of the pan movement during a shot.
Harry
Gunleik Groven October 9th, 2006 01:29 PM
Ok.
Then I would have dropped the HD footage to an SD sequence and adjusted the scaling to suite my needs (remembering to keyframe the scale part in case I would need to change it.
Then I would have found a startingpoint, hit keyframe (in the motions tab), find my next sweetspot, hit keyframe again etc.
Or did I misunderstand again?
Gunleik
Richard Alvarez October 9th, 2006 01:45 PM
http://www.stagetools.com/
Harry Bromley-Davenport October 9th, 2006 01:55 PM
OK. I'll attempt to do that. That's very much for your help.
Harry
