-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Slow Motion Effect (https://www.dvinfo.net/forum/final-cut-suite/85278-slow-motion-effect.html)
Ong Wan Shu January 31st, 2007 03:17 AM
Slow Motion Effect
hi all,
i am using GS500 PAL version and would like to try create scenes with slow motion effect but yet sharp.
So i know i need to get the footage in high shutter first, maybe 1/125? and then what do i do to the clip in FCP? and numeric recommendations would be appreciated just to start me off experimenting
cheers
Andy Mees January 31st, 2007 07:40 AM
http://www.kenstone.net/fcp_homepage...es_motion.html
check out option 5
Gene Crucean February 1st, 2007 01:19 PM
That seems like a lot of work compared to doing it just in FCP.
Just right click (you have a 3 button mouse right?) on the clip in the time line and choose speed. Lower it to whatever you want and hit ok. Select the clip and press apple - r to render it.
... buttery goodness.
Andy Mees February 2nd, 2007 12:35 AM
define "buttery" Gene!
the "lot of work" involved in the Compressor method produces significantly more buttery results than a basic speed change in fcp, which is oft considered rancid by most palettes ;)
