FCP6 Plays HDV timeline direct to DV on the fly at DVinfo.net
Final Cut Suite
Old May 18th, 2007, 08:31 AM   #1
FCP6 Plays back a HDV timeline to DV on the fly, how cool is that.
Also some other formats like ProRes play out through DV on the fly.
James Miller is offline   Reply With Quote
Old May 18th, 2007, 09:33 AM   #2
it's not just a DV thing, James
External Video Monitoring
You can now output to external video interfaces whose settings don’t match those of your sequence. Here are some examples of some of the possibilities:
• DV or HDV sequence output to an SDI signal on a third-party interface
• An uncompressed NTSC or PAL sequence output to a DV FireWire output
• An HDV sequence output to a DV FireWire output
Sequence and output formats must have compatible frame rates. For example, sequences with a frame rate of 60, 30, or 24 fps can be output to a 30 fps device, but not to a 25 or 50 fps device. Also, when an output device does not match your sequence settings, additional real-time processing is required. This means that segments that already require a lot of real-time processing power may need to be rendered to play back.
Andy Mees is offline   Reply With Quote
Old May 18th, 2007, 09:55 AM   #3
Thanks, Andy - I should have read the manual. I was just happy at the time to get a SD preview back on my sony monitor. :-)
Old May 18th, 2007, 05:00 PM   #4
Please clarify this so I don't misunderstand... I am now in shock that this might be possible...
You can play your hdv timeline and have it go into your camera as SD and hook that up to your production monitor for color correction work (in SD)..? Just like it works for an SD timeline?
Scott
Scott Shama is offline   Reply With Quote
Old May 18th, 2007, 05:18 PM   #5
I've been waiting a long time for them to implement this. You could tell they were working on it because HDV devices showed up in the "view" list in FCP5.1.2, but were 'greyed out.'
What about latency? Have they put the interface playback in sync with the HDV stream?
Convergent-Design has a HDV to HD-SDI or Component out box called HDConnect LE. I wonder if the FCP HDV output is compatible with this box?
I've been using Convergent-Design's HDConnect MI with a Belkin DVI to HDMI adapter to get my broadcast HD-SDI signal out of a Macbook Pro and into a pro monitor. It has worked very well, but having HDV instant playback will be a bonus when on set.
Tim Dashwood
Old May 18th, 2007, 05:21 PM   #6
Yep it downsizes on the fly and outputs via the DV Firewire. I had it hooked up to a Sony DVD-R recorder and burned a sample to see if it was a valid signal and it worked.
This means I don't have to get a HD montior to show my client previews on just yet.
Just to confirm HDV and other codecs play backout of the Firewire in FCP6
Old May 18th, 2007, 05:43 PM   #7
Thanks James. I think I may have misunderstood. I thought you meant that HDV material plays out through firewire to a HDV camera or deck. I didn't realize you were downconverting to DV.
That is also very cool, but I'm really hoping selection of HDV devices in external view is now available.
Tim Dashwood
Old May 18th, 2007, 09:44 PM   #8
sorry Tim but that is not possible nor is it ever likely to be so.
HDV is a complex MPEG2 Long GOP codec ... to render a timeline of multiple cuts and clips to an bidirectional predictive codec in software in realtime is impossible with todays desktop computing power.
so just to clarify, depending on your computers processing power (and RAM) and/or any your other third party I/O devices you may have installed, you are able to select an valid output path/format that is not native to your sequence format, and view your timeline via that path.
so HDV timeline monitoring as a (downconverted) DV stream via built-in firewire is one possible option. but monitoring any codec (including native HDV) as an HDV stream is not an option.
Old May 18th, 2007, 11:39 PM   #9
Ok..this is important...does the hdv to sd convert work in Color? Seems like that would be relatively important...
Scott
Old May 19th, 2007, 05:47 AM   #10
Something interesting, when I first opened up FCP, it asked for my project setup. Under, HDV- there were two 720/24P options, one was 720/24P, the other was JVC720/24P (not that anyone else makes 720/24P HDV but JVC). I think the presets for capture were different. I am going to look at it again. Maybe the capture issue was worked out (I use a DR-HD100, so I wouldn't know yet).
Steve Benner is offline   Reply With Quote
Old May 19th, 2007, 06:08 AM   #11
Scott
Scott, i don't have it yet so can't tell you for sure... but common sense suggests that the answer is No.
Features that are part of FCP are not automatically integrated into any other app that forms a part of the FCS suite. In Color the processing power is liely being diverted elsewhere.
To be fair, we also need to consider that Color is a high end color grading software. Any color grading based on eyeing a downconverted interpretation of your HDV timeline would totally defeat the purpose of the software. To grade HD source footage you need a professional HD monitor ... or I dare say we can get away using an MXO to feed a properly calibrated Apple 23" cinema display. Alteranively, it will likely work as you wish using an I/O card as a medium to downconvert the output to an SD monitor.
Bottom line. Whilst Apple provide this high end software at a give away price (to lure professional users as well as those with aspirations) respectfully, if one wants to use it as it is intended, then one needs to get the hardware to go with it.
Old May 19th, 2007, 01:48 PM   #12
Sorry, but I completely disagree...if your intent is to deliver an SD DVD then being able to CC your HDV timeline for proper SD output is essential.
And the hardware that goes with it should just be my firewire out to my cam then out s-video or component out to my SD monitor.....
Scott
Old May 19th, 2007, 08:55 PM   #13
sorry Scott. we were at crossed purposed there. my assumption was that you wanted to grade your HD masterpiece for HD distribution.
yes, for SD distribution you would ideally want to grade an SD downcoversion
i'm afraid you'll still be out of luck though. what you have to appreciate (and what few do) is the professional nature of Color. it is quite simply not intended (at this time) for low-end hardware. I would expect that a future revision will allow it, bringing it more in line with Apple's policy of making the tools more accesible to all users.
but as it stands, for external monitoring, Color supports only a professional broadcast interface ... that means you need some kind of third party I/O hardware. (what they refer to as a "broadcast video interface") Color does not support external monitoring via firewire (or even digital cinema display)
Old May 19th, 2007, 09:00 PM   #14
That sucks....well, at least the BM intensity Pro is only $350 for real time convert from hdv to sd...
Scott
Old May 25th, 2007, 12:08 AM   #15
This thread has both fulfilled and destroyed my dreams for color correction in FCS2. Finally I'll now be able to play back HD sequences over Firewire for live SD monitoring... but the new and improved toolset for color correction won't allow it... I love precise color correction but it's looking more and more like I'm going to have to break down and get the $$$.proper hardware.$$$ for it. Back to the dreaming board I guess.
Chad Terpstra is offline   Reply
