-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP 6.0.1 now supports AVCHD (https://www.dvinfo.net/forum/final-cut-suite/97710-fcp-6-0-1-now-supports-avchd.html)
Iain Anderson June 28th, 2007 12:19 AM
In case you have a Mac and a Sony HD camera you haven't been able to edit with:
http://www.apple.com/support/downloa...cutpro601.html
Final Cut Pro 6.0.1 contains several updates, including:
- Improved stability
- Support for the AVCHD format through the Log and Transfer interface
- FXPlug improvements with Motion and third-party applications
- Improved master template support
- Resolution of issues with long filenames (greater than 32 characters, up to 255 characters) on non-HFS file systems (network or Xsan volumes, FAT32 volumes, and so on)
Updates for the other programs in the suite are also available.
Tim Dashwood June 28th, 2007 12:39 AM
I just ran software update and it is only giving me the option for the Pro Application update.
http://docs.info.apple.com/article.html?artnum=305524
I assume this needs to be installed first?
Tim Dashwood June 28th, 2007 12:41 AM
1 Attachment(s)
Installed Pro Applications update and now I get the full list of Final Cut Studio updates available.
