Apple TV for HDMI output to HD TV
I'm setting up an 8-Core MacPro for editing with Final Cut Studio 2 and was wondering if I could use an Apple TV to output to a 42" HDMI TV for clients to view finished the finished work (we are shooting in 1080/50i with XDCam).
thanks |
You could. Keep in mind that the maximum output on an Apple TV is 720p. If you have an extra DVI output on your Mac Pro, you could get a DVI to HDMI cable and hook it up right to your HDTV.
Thanks Chris, I didn't realize that DVI and HDMI were compatible enough only to necessitate a cable (live and learn).
Yesterday in an Apple store I was looking at an Apple TV box, and it seemed to indicate 1080/50i output? For some reason, however, Apply TV specs are not available on the apple.com site, so I can't seem to verify. I'm curious to know if anyone out there is playing out HD content form a Final Cup Pro timeline to a HDMI full HD TV either via a DVI?HDMI cable, via Apply TV. |
Whoa!
I suspect, but am not sure that for 50hz countries, it would do 25P at 1280x720, and 50i at the lower resolution. I haven't tried setting the output to 720P for feeding the display. Might make for a better picture with less scaling involved. -gb- |
I know there are a few flavors of DVI out there connector-wise (very confusing). Does anyone know if it is possible for my aging 15" G4 Powerbook to be able to output 720p out of FCP6 into a display via HDMI, simply with a cable?
thanks, Chas |
...and discovering now that this will not pass audio into the HDMI cable, which makes things a bit complicated for my home theater interface, so I might be better off with a DVI to component video connection...also easy?
To play HD video on a HDMI tv / monitor. You need a computer with DVI-D monitor output and a DVI to HDMI cable. I use a Mac Mini (DualCore) to drive all kinds of HD-ready screens. I compress my 1080p25 video's with the H264 or the HDV codec in QuickTime. To play the HD movies on PC's I compress with the WMV-9 codec from Popwire.com. The results are very good. We use these set-ups to play HD video's on exhibitions. To play the sound you need a cable from the sound-out port from your PC / Mac to the sound-in port of your HD tv. You can obtain these very easily in electronic stores. Before you make promises to clients. Check, try and recompress. Clients often have PC's with very weak video boards or analoge monitor output. They rent a HD screen and forget to ask for HDMI inputs. Or think a Windows 2000 PC will do the job... So, check, try and recompress until everything works fine. Enjoy!
| All times are GMT -6. The time now is 04:16 AM. |
