-   Flash / Web Video (https://www.dvinfo.net/forum/flash-web-video/)
-   -   12.5 or 15 FPS For Web Delivery? (https://www.dvinfo.net/forum/flash-web-video/109964-12-5-15-fps-web-delivery.html)
Seun Osewa December 11th, 2007 05:20 AM
Hello,
What frame rate would you recommend for delivery of videos over the web? Youtube uses 30fps at a low resolution while Blip.tv uses 15fps at a higher resolution and seems to be getting a lot of praise for quality.
Is 15fps or 12.5fps (PAL) video be considered as "good video"?
Thanks.
Ervin Farkas December 11th, 2007 04:09 PM
Too low
Both of these frame rates will give you a stuttering picture - I would suggest at least 20 fps but do your own testing and see. It also depends on the content, the more you have, the higher FR you need for smooth temporal resolution.
Jon Jaschob December 12th, 2007 01:29 PM
I shoot and deliver in 24fps. My JVC HD100 will shoot 24fps so I have a nice clean workflow with no FR changes.
Jon
Ervin Farkas December 12th, 2007 01:37 PM
I just found my mistake: forgot the word "motion". the more motion you have, the higher frame rate you need. Static images are fine with low FR.
Kaku Ito December 12th, 2007 02:21 PM
Here are some examples in 24p and 30p with 500 x 281 and coresponding 720p files with H.264 formats.
http://www.onebikeguy.com/KakugyoBlo...t/Podcast.html
After doing a lot of research, I decided to shoot in 24p mostly then deliver HD with Bluray 24p and H.264 24p on the net.
