Windows media brightens too much
Hi,
I really like the Windows Media Encoder 9 - BUT, I think it brightens the video too much. Haven't found any setting for the encoder to change brightning-level. Am I alone having this problem? http://www.sidens.se/malar.wmv Here I darkened the video prior to encoding it... the result is OK - 5.8mb file for 1.44 minute video at 15fps ... quality is above average for web-video at least in my opinion :-) // Lazze \\ One more thing - what's your feeling about microsofts MJPEG 4 v2 encoder? |
How did you export this exactly? Did you load up the file in the
standalone encoder or did you export from an NLE? |
I used the stand alone MS Media Converter program.
It's real tricky making the judgement for web video... quality or size.. viewing size... is it going to be viewed on CRT or TFT... |
It definitely is and therefore you can never really get it right. It
will look different on all systems. I haven't used the WM encoder myself so I don't know it does, doesn't do or how you can influence it, but it sure does sound strange it would brighten it. Perhaps this is due to some automatic settings that tries to level the exposure or something? (just a wild guess). Otherwise you might try a WM export from your NLE. |
I have had this exact same problem with the Windows Media Encoder 9 series. I can't remember having it when I export from within Premiere Pro v1, though.
Christopher |
| All times are GMT -6. The time now is 08:29 AM. |
