-   Flying Cameras (https://www.dvinfo.net/forum/flying-cameras/)
-   -   Early leak: FAA will require a pilot's license for drone flying (https://www.dvinfo.net/forum/flying-cameras/525856-early-leak-faa-will-require-pilots-license-drone-flying.html)
Robert Benda November 24th, 2014 01:47 PM
Along with an actual pilot's license, it would be restricted to daylight hours, under 400 feet, and within line of site. This would include all unmanned craft under 55lbs.
Report: FAA Will Require You to Have a Pilot License to Fly a Drone
The only good news is, this is in the stage of being passed around for comment. Should be a couple of years before any of this is law.
Chris Medico November 24th, 2014 03:18 PM
Re: Early leak: FAA will require a pilot's license for drone flying
1 Attachment(s)
I was giving a workshop for drone flying over the weekend and this was one of the topics of discussion.
Everyone should read the exemptions given to the crews flying for the film industry right now. That is likely what will be handed down to the rest of us in due time.
Edit - Here is the summary slide from that part of the presentation.
Nate Haustein November 24th, 2014 06:49 PM
I'm all for reasonable regulations, but unless the FAA requires you to log 25 flight hours in a yet-to-be-invented human-size multirotor, I'm failing to see how flying a fixed wing aircraft has any educational benefit when the final goal is operating a remote controlled UAS from the ground. ESPECIALLY when there's no longer the option for FPV. Do they teach you how to fly a Cessna with a 14 channel Futaba? It's seems to me a 25 hour class and skills test tailored to UAS would be a much more beneficial. Half the battle here seems to be making sure operators know and above by the rules of the air. Fixed wing aircraft flight experience has no reasonable benefit here, a multirotor doesn't even have wings!
Chris Medico November 24th, 2014 07:21 PM
I'm looking at it like this.. 1. The current providers with exceptions want the price of entry to be high enough to discourage newcomers. 2. The government is inherently lazy. Its is much easier for them to make UAV operators conform to existing rules than it is thinking about what is reasonable and appropriate.
Jim Michael November 24th, 2014 07:46 PM
Yes, but will the flight time count towards the ATP certificate requirements?
Brian Drysdale November 25th, 2014 01:54 AM
The UK's CAA regulations seem to make more sense in the longer term, this has the paper examinations, plus a test flying an appropriate drone. On the larger drones, the aircraft sized ones, a full pilot's license of a suitable class would be seem correct.
Don Palomaki November 25th, 2014 06:17 AM
And maybe next will be FCC license for the remote controls and operators????.
The underlying issue is to reduce conjestion, accidents, and the number of idiots behind the stick.
When drones in the air crash into each other, things on the ground get fallen upon.
Chris Medico November 25th, 2014 07:15 AM
Once the Notice of Proposed Rule Making comes out there will be a comment period. If the minimum license requirement in the proposal is a Private ticket then that is what the rules will be. It will be up to the community to push for a special license. Otherwise you will be stuck getting a full license to fly something you can't ride in.
Mark Dobson November 27th, 2014 12:09 AM
It would seem the FAA are looking adopt many of the working practices that are in force in the UK for commercial drone operators. The key word here is commercial. If you are simply someone who enjoys flying drones these restrictions won't stop you going out and having fun.
It looks like the FAA will be adopting something very similar to the BNUC (Basic National UAS Certificate). This is the preferred pilot qualification standard required by many National Aviation Authorities before a Permission for Aerial Work or Exemption is granted to an operator.
And it's all to do with developing and maintaining safe procedures and working practices. Here in the UK getting a CAA permission for aerial work is a pretty rigorous process that involves attending a ground school, and passing an initial examination before developing and maintaining an operations manual as well as passing a flight test that assesses both the pilot and the craft.
Whilst all this might seem over the top for someone who just wants to take a few aerial videos of, for instance, houses for sale with a DJI Phantom what it does teach you is to operate in as safe a manner as is possible regardless of the size of the UAS you are flying.
Gaining the certification to carry out commercial work is a powerful marketing tool and clearly separates the professional operators from the hobbyist amateur flyers.
Andrew Gough November 27th, 2014 10:20 AM
As someone who has a Commercial Pilots licence, I am in full support of this. The problem with fly away drones, and uncontrolled use of airspace represents a significant risk to commercial aviation. We have seen drones being flown on commercial flight paths putting numerous flights at risk. We regularly see video of 4 engine drones being flown over crowds with no consideration of the risks to individuals below. I have seen videos of drones at 4000-5000ft in densely populated airspace.
The bottom line is, this is coming, and our company is prepared, insured and ready to fly. To get ready for this type of regulation, represented a significant cost and time investment. Lets face it, we all knew that the industry could never continue unregulated...
So yes, flying a Cessna would make you aware of flight regulations, airspace and the ramifications of what you are doing.
David Heath November 28th, 2014 07:24 PM
Further to Marks post, the key word from the original link that seems to be getting missed out of most of this discussion is that these are proposals for "commercial" users - not hobbyists.
One way in which they could be out of date as soon as they are written is if companies like Amazon are serious about the use of drones for deliveries. Such is obviously a commercial use - but very different to any use for such as aerial filming, with a completely different risk assessment.
The risk of aerial filming use may be down to their being far more likely to be being flown near lots of people - it's filming people/events where they're most likely to want to be used! The main risks for delivery drones are more likely down to their having to be flown autonomously, without human supervision.
Or may that be a safety plus? I suppose it depends on just what technology in terms of collision avoidance etc may get developed in the next decade or so. Part of me just doesn't think it likely to happen - but I don't think I'd have credited even 10 years ago - let alone 20 - what modern technology is capable of today. And Jeff Bezos and Amazon certainly have the resources to make it happen if anyone does.....
Donald McPherson November 29th, 2014 03:58 AM
There should be clear guidelines in the box explaining where and more importantly where not to fly these things. Say I'm out in the Scottish country flying one and a RAF fighter jet fly's past at low level. Hate to think. So yes we need some guidelines.
Brian Drysdale November 29th, 2014 07:39 AM
Airspace restrictions is a subject you find out about when studying for the ground exams. The locations for military training are marked on charts and NOTAMS are available online Flight Planning Map: UK | NOTAM Info
Jim Michael November 29th, 2014 07:55 AM
USA and UK are signatories to aviation treaties which tend to result in a lot of similarities between the regulations, so I wouldn't be surprised if the FAA NPR contains much of the same rules as those in the UK. It makes sense - if I fly to Canada I would prefer not to have to learn a new set of regulations, or worse have to take a test in order to use the airspace. Likewise if drone related rules are consistent, then you should be able to fly your drone in another country with less risk of violating a regulation.
Kevin Martorana November 30th, 2014 08:57 PM
First of all...I agree with almost all the statements in this thread.
My two cents:
In the early 1990's I bought a JetSki. Anyone could buy and take one on a lake, river etc. Problem was, lots of IDIOTS bought them and did idiotic things with them due to the lack of common sense. Accidents with jetski's began to soar. You see... when going 45mph on a jet ski...it doens't have brakes (today they do..like thrust reversers on a jet). So if you're about to T-bone a boat, taking your hand off the throttle doesn't do much....you keep cruising into the boat. You have to actually APPLY POWER and turn away. Not something that is INTUITIVE.
Finally, in Pennsylvania where I live, you needed to have a boating license to operate a jetski. Ok. I was for that. Accidents did go down. Did it stop all the idiots from purchasing skis and doing dumb things with them ? No. The jet ski industry had to begin to make the skis safer (the brakes I referred to).
We have a DJI Phantom2 Vision+ with a GoPro Hero3+ for 4 months now. It is an amazing tool in our arsenal of video equipment needed to survive in producing work today.
After using it this long, at no time have I needed to obtain footage higher than 400' AGL. Matter of fact I only went that high ONCE...to just see the view ! We have shoot exteriors for colleges, corporations and stock broll of farms, fields creeks...etc. If I was higher than 150' it was unusual. Why ? Because higher than than usually gets you just tops of buildings. I understand shooting fields wide shots and it looks great. But 1500' AGL gets you GOOGLE EARTH.
We use the drone for many shots like jib replacements and crane shots. Most of these never go higher than 100'. If I have a private or commercial plane, flying at 100-400' over a campus, river, cornfield or ANYTHING...we have a bigger problem than my drone.
OH..Privacy issue. If I'm being hired by a corporation, university or private entity that is AUTHORIZING me to get footage for a project for them...how can the FAA control that ? Right now they say they can.
So, should a test and license be made for us in the production world to show we know how to operate a drone and use 'reasonable intelligence' when flying one....like the boat license ? SURE. I'm in. Will it stop idiots from flying 2000'AGL near an airport or anywhere for that matter ? No.
The manufacturers are already putting safety stops in place in their software/hardware. Our latest firmware for the DJI includes max flight heights. Ours is set to 400'. Also max distances so flyaways wouldn't go a mile or so if it happened. The new Inspire is awesome. Using a two controller system for pilot and cameraman.
Since day one we instituted this system. Pilot watches the drone for obstructions. Cameraman has the monitor with a 5.8ghz system to direct the shots verbally. The camera is similar to a side view mirror...Images appear closer than they actually are. Yup. So two people is the way to fly. No question.
Someone posted a drone video on Youtube. He was flying it in Times Square. Within one block he lost control (gee..wonder why with every type of wireless signal flying around in there) and it crashed 2 times into a building and fell. I was DELIGHTED to see that people who commented castrated this person. It 's not funny and this type of video is what will hurt our business, whether it be enthusiasts or production people who use the tool properly. He was asked to take it down...but he hasn't.
As a kid...and even today...I still fly model rockets for friends and their kids. These rockets can go 2000' easily. Most...about 1000'. What about them ? Just because they can't fly for 15 minutes...does that make them not an issue. When I saw a plane in the area....I just waited until launch ! But that's a bit off-topic.
So what do we do as a community whom.....I guess understands the issues....but has the INTELLIGENCE to use this tool properly for the the work we do. Here's hoping the manufacturers continue to build the safety restrictions into their products (jetski brakes=max altitude settings) and if we need to take a test to prove we understand the issues and can fly the drone properly...I'm for it. But don't tell me I need a private pilots license.
Brent Kaplan November 30th, 2014 09:06 PM
The FAA chairman was Interviewed on ABC network this morning, he spoke about many subjects and whe asked about Drones he suggested that they stay away from airports, fly craft in line of sight and stay under 400 feet.
Jim Michael November 30th, 2014 09:48 PM
Looks like this one is a tad over 400 feet and apparently a commercial operator.
https://www.youtube.com/watch?v=f1Bg...ature=youtu.be
Brent Kaplan November 30th, 2014 10:51 PM
True, but its a good example of the exception. Safe to fly a drone but keep aircraft away
Brian Drysdale December 1st, 2014 02:07 AM
I suspect for shoots like that one, there'd be a a procedure in place to get a clearance from the appropriate aviation authority. For example, I've been filming in a helicopter approx 50ft from the top of a 650ft power station chimney - the station wasn't yet running at the time, that would need special permission.
Jim Michael December 1st, 2014 05:40 AM
To keep aircraft away you file a NOTAM, but you can't do that in the current environment.
Mark Dobson December 1st, 2014 11:58 AM
............... But don't tell me I need a private pilots license.
Hi Kevin,
loved your post, great to hear from someone with your experience, ( 2" tape !, I only go back to Umatic tapes) who's as excited as I am by the possibilities of these very accessible flying cameras. And I've got my order in for the DJI Inspire 1 which unfortunately has been delayed whilst they design an eyelid for the camera.
If you were over here in the UK I'm sure you would already have taken advantage of the BNUC-S™ pilots qualification and from your description of how and where you work you would breeze through the course as it's all pretty much to do with getting permission to fly from the landowner, checking there are no other low level aviation activities near you location, keeping an accurate log of you flying operations and a maintenance log of your aircraft and batteries.
But here in the UK the law is clear. You cannot operate a UAV commercially without this license. The companies supplying the training are having a bumper crop time with a huge take up of companies pushing people to get this accreditation.
I think there will be a clear delineation in the market between people like me who are happy with the quality of a mounted gopro 4 for example, or an Inspire 1 and those flying the larger UAVs with C300s or GH4s strapped onto them.
Between the slowly emerging 4K market place and the rise of the drone these are exciting times for grown up kids.
Mark
Kevin Martorana December 1st, 2014 05:10 PM
Mark...
thanks for you view from over the pond !!!!! I TOTALLY agree with having some sort of qualifications/license, etc to show that we are intelligent, law abiding folks who want to use this "TOOL" for our business. And you are correct....if you want to fly a 20k quadcopter with a RED or larger camera on it....then you are clearly working in a much higher production level and should have the FAA approvals. With the GoPro technology with just HD...forget about 4k. HD still looks great....but with this technology, we are able to do MULTIPLE crane-esk and jib-esk shots in MINUTES. And we weren't flying higher than 50' for these shots !!!
Yes...the Inspire looks cool. I assume every 6 months these things will change like cell phones. Right now our Phantom2+ with a Hero 3+ works just great for the work we're doing.
I hope the US will take heed...and look at what you have done in the UK and make some changes.
David Heath December 2nd, 2014 07:41 PM
Yes, I also agree with all Kevin says. One thing that I do think he may have missed out though is any requirement to have insurance etc, certainly for commercial use. It's just one more reason why some form of regulation for such use makes sense - but let's not go over the top.
The jet-ski analogy is also a good one, but I'd take it further in that once such things get licensed it establishes a legal framework for what may and may not be at least good practice. Consequently, even if people will still do stupid things, it then becomes far easier to successfully sue when they go wrong. (And gives protection to operators who abide by the rules, for that matter.)
(And on the subject of 2" tape - when we're talking about editing, was that all tape-tape, or did you ever have the fun of physically cut editing?)
Chris Medico December 3rd, 2014 06:30 AM
Originally Posted by Kevin Martorana (Post 1869447)
Mark...
Lets not ignore the real possibility that the rules when they come out will likely have hardware requirements as well as operator requirements.
If they put in place the requirements that I'm hypothesizing will be in there, small platforms like the Phantom will not be allowed for commercial operation. Maybe a special version but not the off the shelf stuff we are all buying right now. At a minimum I'm guessing that it will take a machine that has been approved to fly via a TSOa (Technical Standard Order Authorization). Exactly what that looks like I don't know. It won't be cheap regardless. Nothing that flies under the FAA umbrella is ever going to be cheap.
So don't get so caught up on the license issue that you miss the hardware stuff. Otherwise spending a few thousand on a license will be nothing compared to the $20k "approved" platform you'll have to buy to fly for hire.
You can bet there is a lobby already pushing that agenda to keep small operators from competing in the market.
Mark Williams December 3rd, 2014 11:57 AM
Due to the impending regulations I will not be able to pay the government's "entry" price nor have the time to be certified to FAA standards to do commercial work. I have sold all my training quadcopter gear and am moving on to other things.
Brian Drysdale December 3rd, 2014 02:41 PM
In the UK, 20kg seems to be the weight which introduces more complex requirements for the unmanned aircraft.
David Heath December 3rd, 2014 05:07 PM
Regarding a minimum hardware requirement, that seems overkill for a lot of work, ("commercial" only means "you get paid something" after all), but pretty sensible for other jobs.
If somebody's commercial work is (say) taking aerials of properties with few or no people around, it seems silly to make them follow the same regulations as (say) broadcasters wanting to use a drone for a major event over the heads of thousands of people. Surely the former only demands a basic and simple licence, whilst in the latter there's a very good case for a minimum hardware requirement and a degree of redundancy, quite apart from the licensing issues?
Chris Medico December 3rd, 2014 07:10 PM
One has to understand that the FAA isn't under a mandate to be fair, reasonable, accommodating, or any other descriptor suggesting common sense. They are evaluating things with the narrow focus of safety. They are risk averse. It will be the responsibility of lawmakers and other interested parties (users and industry) to push back against "safety at any cost" so a reasonable compromise can be struck.
