folder empty after connecting with laptop
It's not that I am really happy with my (second) DR-HD100 but from time to time it's a mess and I don't know why.
I had the following situation several times, especially with a Dell Inspiron 9400. I connect both units, the Dell recognizes the HD. All fine untill I try to import files with Avid Liquid 7. It starts, interrupt showing a message that the files´format is not supported. Trying it again files have disapeared, both in Liquid's import manager and Windows Explorer. I would be really glad to get a hint for what could be the reason. Markus |
Hi Markus
I have not own a DR-HD100, but FS-4HD. Have you set the correct recording format on the unit? Since you are using Avid Liquid 7. Nonlinear Editing System Compatibility DR-HD100 are recorded to disk as RawDV, AVI Type 1, AVI Type 2, AVI Type 2 24p, Matrox AVI, Canopus AVI, QuickTime, QuickTime 24p, Avid OMF, Pinnacle AVI or MXF. In HD mode, 720p clips are recorded as M2T (720p24, 25, 30, 50 or 60) files or QuickTime HDV (720p24, 25 or 30). |
For shure I've chosen the right format and the fact is that from time to time it even works on the Laptop and quite frequently on the desktop editing with both Liquid. I know there are some limitations with that software. For example I can't use DR-HD1000 to edit directly from it without copying. Even if it works in the editing on timeline it fails exporting the edited story to another format, i.e. MPEG or WMV.
But it's a mess that files disapear without chance to get them back! |
I would copy the files to your local hard drive first as a safety measure and then import them, though if the firewire connection is being broken you may continue to experience corrupted file systems. I would also try some FAT32 recovery programs to see if the FAT32 system is still there. Unfortunately FAT32 is not as rendundant with file allocation as NTFS, so power interruptions during a transfer can cause all kinds of damage, but quite often these third party programs can reconstruct it. |
| All times are GMT -6. The time now is 08:02 AM. |
