FS-C in Production?
Does the FS-C 60GB model exist at this point? B&H says they are accepting orders now for a future shipment. Is it in stock anywhere?
status of beta testing
Does anyone know the status of the beta testing for the update for the FSC(that is, the one that will support 24f in QT)?
I spoke to a reliable source and I am being told that the FS-C is ready to go but Canon and Focus can't agree on some parts of the agreement for the C model of the firestore and that is what all of the delay has been. Meanwhile, we wait.
What are you talking about !
I have a FS-c 100 for two months now so its available . The only feature that is not enabled is 30f . Other than that it's great.
Doug T ESPN/ABC |
Doug, do you mean that your FSC records 24f in Quicktime?
Doug,
$20 says the code your 100GB model is running is different than what Focus and Canon are getting ready to release now. Tom |
I was a beta tester so you lose again !
I have the latests software that I got from focus today so you are wrong again !
Doug version 2.0.0.04092006: - Native QuickTime HDV DTE format. - HD TC display and restripe capabilities in Native QuickTime HDV DTE format - MXF OPatom DV DTE format. - Added ORGANIZE MXF for MXF OPatom support. - Added HDV TC TYPE menu functionality for HDV TC playback. - Improved DV FORMAT QUICKTIME 24P compatibility. - Improved disk handling. - Improved HD playback functionality. - Handle 999 clip limit properly. |
any this
FS-C version 2.1 beta version 2.1.0 04112206
Thank you for participating in the FS-C version 2.1 beta test program. We appreciate your help! Attached is the first 2.1 beta release version. Please upgrade your unit as per the instructions in the manual. If you need to return to the current shipping version of software, simply load version 2.0 (also attached). Per the beta agreement, do not distribute this software. New Features When in HDV record mode and QUICKTIME is the selected format, it is now possible to record 1080i/24F, 25F and 30F streams to disk in QuickTime format. sincerely Doug T Send me a six pack you lose ! lol |
Doug,
Let’s get real here. Beta is called Beta for a reason. I means the software is in a phase where bugs are still being worked out and it hasn’t yet reached production status. The code may be complete and ready to go but I'm hearing from reliable sources that there is an "agreement" of some sort that Canon and Focus are still working out and that is the reason the FS-C 60GB model is not shipping right now which is a good thing as I'm not interested in a "patched" FS-C with Beta code. Understand, your Beta code may very well be the final product but I'd rather have it straight from Focus/Canon. Tom |
Canon XLH1 24f user here with question.
There seems to be a great deal of confusion about which firestore model does what. And, apparently, the manufacturers themselves are not too reliable about their own specs.
Can some kind and knowledgeable soul inform me what my options are for use with my Canon XLH1? I also did hear at one stage that these units are kinda noisy - perhaps too noisy for use at close quarters for quiet dialog in filmed drama. Could anyone be so kind as to give me an opinion on this? Many thanks, Best Harry |
Is the FS-C even available right now? Where is it in stock!?!?
i couldn't find it anywhere about a month ago
http://www.bhphotovideo.com/bnh/cont...ist&sku=434414
My question is why can`t they do timelapse in HDV? Seems pretty bad to mix DV timelapsed footage with HDV footage if they are for the same project |
Because the HDV video structure, with 15 frames grouped together and inherently interrelated, makes it very hard (computationally) to get a single frame. The Firestore is a "dumb" device - it doesn't do any actual decoding (and reencoding) of the video stream, which would be required to do a time lapse with HDV. They just write data to disk.
So yeah, it's easy in DV where you can extract any frame individually, not so easy in HDV. |
From my experience with the XLH1 and FS4ProHD and Edius is that it works great in DV --- but in HDV it is problematic.
The FSC firestore is the model now made specifically for the XLH1 (and presumably the A1 and G1). But I have no experience with the FS-C. I am trying to find someone who has experienced reliable HDV results in all frame rates and in both m2t and QT file formats. Bottom line, if you are going to make the leap with a Firestore for the Canon, stick with the FS-C. |
If you ever shoot for editors using Final Cut Pro (a huge group), then supplying files/footage shot in the QTfile format wrapper is an important consideration.
If you are always shooting for yourself, then it may not be an issue for you. We've never had an FS-C ourselves, only the FS4ProHD. And sad to say they have sat pretty much unused except for occasional standard def DV usage - and even then we chose not to bother much with it unfortunately. |
John,
I appreciate your comments. Thank you. |
Wade,
I use and FS-4Pro HD with my A1 and Vegas 7 and it works perfectly in Standard Definition. In HDV there are some issues with the m2t files it creates. 1. The Retro Cache does not work. It creates corrupted files. I am working with Focus Enhancements on the issue, but it is not solved. 2. Since the FS-4 breaks the files about every 8.5 minutes, they do not join together seamlessly. However, Danny Fye has written a .bat file to concatenate them and create a single file with no breaks. (Search this forum for the file.) Buddy |
Buddy,
Yes, I've read the sticky in here referencing the work-around by Danny Fye. I'm glad to hear that SD works without a hitch though. Thanks. Sounds like it isn't worth the extra dollars to go with the FS-C. |
I've been working for some weeks now with a Firestore FS4 PRO HD (80gb), in combination with a Canon XH A1. It does work without any problem, either in sd or hd.
I use Final Cut Pro. I do not understand all the bashing of the Firestore at all, as it saved me hours of capturing time, and it's so easy to work with. The only smaller problem is the firewire cable into the harddisk, I have to check a lot if it's still connected firmly. An angled cable would solve this though. |
Eugene,
I assume you record the files as QuickTime with the FS-4. Do you use Retro Record successfully? I use a Windows PC with QuickTime Pro, but can't seem to play the QuickTime HD files created with the FS-4. Do you have any idea why not? Buddy |
Hi Buddy, I record the files as Quicktime yes. I haven't checked the Retro Record modus yet. It's not that essential for me... |
For those with the FS-C unit, does it give you the ability to record tapes that have been previously recorded? In other words, can I take a tape I shot last week, play it back in the camera and create files inside the unit?
Thanks a ton, Brian Spatz |
Okay...just spent 20 minutes reading the entire thread...wow.
We have a H1... Has anyone successfully used ANY version of the Focus Enhancement Firestore...to record HD, 1080/24f and then bring it into an AVID ADRENALINE ? Right now we have to use a Convergence Connect box to bring in the footage real time...via HDSDI. Sucks because talking with the camera is difficult AND hard on the H1. At NAB...AVID guys were running around with a Firestore and H1...we stopped two of them and asked how they were editing the footage....answer: "uh...we havent' figured that out yet" ! REALLY ???? Any suggestions ? Thanks ! |
status of 2.1 beta for FS-C?
Based on the status of this thread, and the lack of info on FE's website regarding firmware v2.1, I thought I would try to revive this conversation.
Is there any update on the FS-C v2.1 update that will add quicktime file support for 1080i 24F? or any other model that will add this capability? Thanks. |
Jim, I've been wondering the same thing and the only solution I can find, even after talking with the Focus Enhancements sales rep is the Canon FSC-60/100 Firestore. Since it is made by and for a Canon it will support all Canon codecs and frame rates. They are a little pricey but I think the lack of headache and frustration will make up for that...
FS-4Pro HD and XH-A1
A real quick question...
I'm interested in buying the FS-4Pro HD, but am unsure if it supports all the recording modes of the Canon XH-A1. Thanks. |
Only the FS-C will support all of the A1s format. I believe the FS-4 series supports the 60i/m2t files.
hi
i live in the uk where can i pruchase the firestore for canon?
Holdan Limited, Unit 2 Waterside Business Park, Hadfield, Glossop, SK13 1BE, United Kingdom http://www.holdan.co.uk/focus/fs4.htm I bought a FireStore FS-4 Pro 60 GB with my A1 (I didn't know about the existence of the FS-C). The Holdan website is a bit vague about whether you can actually buy the FS-C here - the left hand side of the age states: QUOTE: FireStore FS-4Pro HD / FS-C The FireStore FS-4Pro HD & FS-C Portable DTE Recorder brings all of the features of the FireStore FS-4Pro to DV and HDV camcorders and editing systems. Using reels, the FS-4Pro HD 60Gb /FS-C 60 Gb makes it easy to categorize clips by placing them in prenamed folders on the disk while you shoot. 90 Minute Battery Supplied. FS-4Pro 80Gb/100Gb/FS-C 100Gb - 180 Minute Battery Supplied. Supports: SD - Raw DV, AVI Type 1&2, Matrox & Canopus AVI & QuickTime, P2 MXF(DVCPRO25), Pinnacle AVI, AVID OMF & DV-MXF. HDV - 720p/1080i (*.m2t) and QT 1080i 50/60 /QUOTE but the right hand side specifies models and prices: QUOTE: Focus FS-4 Portable DTE Recorders are available in two models The FS-4 HD and the FS-4Pro HD (available in 60/80/100Gb) Model FS-4 HD 60Gb FS-4Pro HD 60Gb FS-4Pro HD 80Gb FS-4Pro HD 100Gb /QUOTE so I'm still mystified. How about you email them and find out and tell us here? |
firmware for the fs-c
hi .. any update from matt, or anyone on this ?
if i buy a new fs-c tomorrow, will it be capable of shooting 60i, 30f and 24f ? thanks ... sk |
What's the Firestore Canon Compatibility Update
I had the same question about the FS-C, does it support all recording types the Canon XH can create.
I read that Focus Enhancements filed for bankruptcy in September 2008 and their stock has been worth less than a penny for some time. I also read they have a new product, the FS-5. Focus also has a DTE version for the Panny 200, and I believe a JVC version also exists. I don't know how well a bankrupt company delivers technical support, so if anyone has any experience with FE and their products in the last 3-6 months, let us know. Thanks for any updates. |
The FS-C is the model specifically for Canon cameras. It supports ALL the modes the Canon XH-A1 outputs.
Julian |
I just received an upgrade(2.1.3) and it seems to work fine! I can record in m2t or QT HD.
Email me for the update, I'll send them asap. |
I recently purchased an FS-C on eBay. It arrived with a broken firewire connector. I emailed Focus Enhancements Tech Support and after receiving no reply I called their California office. There I spoke to a tech support person who gave me a repair number and told me to ship the system to them. Because it was still within the two-year warranty period, they repaired the unit for free and even shipped it back to me at their expense. The only cost I had was $18 to ship the unit to them - and the eBay seller reimbursed me for that. So, my experience with their tech support while in bankruptcy has been excellent (except for the unanswered email). |
| All times are GMT -6. The time now is 04:38 AM. |
