50p for DVD
Hello,
I mainly use Panasonic camcorder TM700 which produces stunning 1080/50p footage. I have seen many DVD-players in the market that advertise they support Progressive Playback. I am wondering: if I output my movies to 576/50p will they be playable by those players ? Same goes for BDplayers, could output to 1080/50p ? |
Re: 50p for DVD
In the SD world 50p is not a valid frame rate.
50p is HD only will require a blu-ray compatible player. |
Re: 50p for DVD
Nonsense! ^^
I shoot sports at 720 50p and downconvert to SD DVDs and the footage is good! |
Re: 50p for DVD
It may be true the output looks good but is not 50p on the SD DVD. SD DVD does not support a 50p stream. It will be converted to 25p. |
Re: 50p for DVD
what about BDplayers that support progressive playback ?
Could they play 1080/50p material written in Blu-ray format ? |
Re: 50p for DVD
Unfortunately 1080p50 is not in the Blu-Ray standard as of now. 720p50 is in the standard.
Re: 50p for DVD
Re: 50p for DVD
You may use 720p50 as your source material but it will be converted to an appropriate SD format when encoded for the DVD. |
Re: 50p for DVD
You really should listen to Chris, he is 100% correct |
Re: 50p for DVD
Thanks Colin, I was beginning to think I was in a parallel universe.
Re: 50p for DVD
Quite right Chris, I was simply enforcing your reply to Jalan
Re: 50p for DVD
In that instance I should have been reading more carefully. ;) |
| All times are GMT -6. The time now is 09:43 AM. |
