JVC GY-HD100 720 True 24P or Sony HVR-Z1U 1080 60i converted to 24P?
Hi Everyone,
I've been holding off from purchasing an HDV camera for a while, but I'm getting close to buying one. Even though they both make me drool, I don't think I will be able to afford a Canon XL H1 (cost of camera) or a Panasonic HVX-200 (cost of camera and P2 storage), so I'm trying to decide between the Sony HVR-Z1U or the JVC GY-HD100. I want the camera to shoot short films and a low-budget feature (potential film-out). So, I've been researching both 720 24P (from the JVC) and converting 1080 60i (from the Sony) to 24P via DVFilm Maker. My question is, if I'm going to film-out a project, which camera would be better? The JVC footage is true 24P, however it's recorded at 1280X720. The Sony records 1440X1080 with anamorphic pixels, but if I converted this footage to 24P, would the interpolation within DVFilm Maker soften the image, negating the advantage of shooting with the higher resolution? Has anyone seen side by side comparissons? (720 True 24P vs. 1080 60i converted to 24P) Any information would be greatly appreciated. -Geoff Murillo |
Without doing a side by side comparison, I would vote for the JVC in theory as
The best solution would be to get your hands on the cams yourself and shoot tests, where you can tailor the conditions to your own situation (eg are you shooting in low key/high key light, fast action, or trying to get a particular look?) Talk to the lab that will do the blow up and get their opinion (DVfilm might be willing to answer some queries, they have a FAQ list on their site but it's a little out of date.) |
* the Z1 is 60i, which risks adding more compression artefacts motion on detail that's essentially wasted.*
The Z1 can be switched to 50i or CF25 which would eliminate the need for pulldown software. And depending on the route chosen, preserve resolution and/or eliminate interlacing artifacts. * it's a much simpler workflow, if you're really set on 24p you're going directly there, no interlacing/slowing down footage.* I'm not an editor, but I am not aware of any plug and play NLE solutions that can handle native 720/24P HDV. To the best of my knowledge, 720/30P is the only native HDV setup on most, if not all, desktop NLE's. I've been shooting a demo with the HD100 for the last few days and know for a fact that you can't cut natively with FCP5. * for the HD100 you could rent much better HD lenses than the stock lens and really get the best out of the 1280*720p resolution.* Don't be so quick to think you have many HD lens options. I'm not aware of any other 1/3" or 1/2" HD lenses other than what Fuji is offering. * a true manual lens* Always preferable. If you're not going to use the 50i switchability of the Z1, then the FX1 gives you the exact same camera and lens for alot less. But then you'd have to go the 60i to 24fps software pulldown route. |
Verified, Vegas does indeed play 720/24p HDV files. It also can play the Canon 1080/24F files.
The only real advantage you get from down converting 1080i to 720p is being able to actually create a slightly lower resolution 720p video at a true 50 or 60 fps.
Current 720p HDV equipment can only record up to 30p which is great but for some people used to interlaced video they find 30p to jerky and not as smooth. Converting 1080i to 720p with the right tools will give you 1440 x 540 x 60. You then scale that to 1280x720x60. So you will have a slightly softer 720p due to starting with 540 pixels instead of the full 720p. So really you will have 720p video at 60p with about the same amount of detail as the SONY Cineframe modes since only only use one field worth of detail. Of course it is actually less when you take into consideration interlace filtering. You may only really have 410 lines of detail with this method but the horizontal resolution would be a full 1280 and you would have 60 frames per second. For all the mess however I would prefer to deal with the 30p of a real 720p. |
Barry & Spot,
I've been shooting with the HD100 for a few days now, and I'm still at a loss for how it is recording the 24P to tape when recording 720 HDV. The manual states that a 3:2 pulldown is used to covert the 24P to "60 frames". But it doesn't specify whether or not the recording is interlaced or Progressive. Any ideas? Vegas... Here's a some questions: Can Vegas detect whether or not the recording is i or P? Is the preset in Vegas actually 720/24P or 720/60? When the footage comes into Vegas what needs to be done to work with the footage on a 23.98 timeline? Does the Vegas 720 preset keep the footage in Native HDV when coming in through Firewire, or convert it to/from something else? In other words, is the preset actually an HDV preset, or just a generic 720/24P preset? More importantly, have either of you actually captured 720/24P footage from the HD100 via Firewire into Vegas and cut it? How was the workflow? Any eccentricities? How did you get it back out of Vegas and onto what format? |
Barry's had a lot more quality time with the cam, I think, so he'd be a better judge of that side of things, I'm sure. |
I'd be happy to make comparison pix if you'd like to find a piece of footage that serves as a baseline. It might be you've got a better way. I'm judging my footage on a Luma monitor and on a 12' projection screen. |
Remember, during the downconversion from 1080i to 720p you lose resolution. Based on every person that has posted here their opinion, that is their subjective opinion. On the other hand, going from 720p to 1080i is easy and you do not lose any resolution.
Not to mention that 720p is a square pixel format and 1080 i or p is anamorphic/non-square pixel format. In the overall process, downscaling is less difficult than upscaling. |
In the MPEG-2 data stream, yes it's a 60p file. The duplicate frames are handled with a simple "repeat" flag, which takes up no bandwidth -- so you get the compression efficiency of only storing 24 frames' worth of data, but you get the compatibility of it being a 60p file. Remember, 24P is *not* one of the HDV standards; just like 24P is not a DV standard. In DV 24p was implemented by carrying it within a 60i data stream; in HDV it's been implemented by carrying it within a 60P data stream. Now, here's where it gets a little weird -- in editing, Vegas sees the file as 24p. Not as 60p. I haven't captured any HDV in Vegas yet (just upgraded a couple of days ago) but I've captured it using Pixela HD Capture and using HDV Rack. Both write .m2t files to the disk, and when you drop those .m2t's into the Vegas media bin, the properties show "23.976 fps". I don't know quite how to explain that, but it's really cool, and it continually impresses me how forward-thinking Vegas is. Quote:
[quote]Does the Vegas 720 preset keep the footage in Native HDV when coming in through Firewire, or convert it to/from something else? In other words, is the preset actually an HDV preset, or just a generic 720/24P preset?[quote] Haven't captured through Vegas yet, so I defer to others to answer that. Quote:
"720/24p, but you have to create that preset on your own, as the JVC wasn't available when Vegas 6c was built. However, creating a preset takes about 4 seconds. Either have "Remove Pulldown" checked in the Prefs, or right click the footage and in the properties instruct it to remove. "
Wait a minute... Now I'm confused. If Vegas doesn't touch the stream and can't detect whether or not the stream is Progressive or interlaced, then how does it know what to look for when it is capturing and why would you need to tell it to "remove pulldown" if it was told to capture a 24P stream? Maybe this shows my ignorance in the world of post, or perhaps I'm too sheltered in my own little FCP universe, but it seems to me that you would need to tell Vegas that the HDV footage was 720/60 in order to capture it via Firewire in the first place. If you tell Vegas the footage is 720/24P, wouldn't it look to capture 24fps and not know that the 24P was pulled down to 60fps to record? I'm not at all talking about working with the files once it's captured. I can easily create my own custom presets in FCP too. But when it comes to capture, that's a different story. So, does Vegas actually capture 720/24P natively via a Firewire connection, directly from the HD100's 6 pin 1394 port, or do you have to create some sort of unique setup to get the footage into the system? |
I'll be in NYC in a couple weeks...if you'd like, I'll be happy to take some time and show you the ins/outs of why many feel Vegas is a superior editor for HDV. :-) |
I have been writing a program to convert 1080i video into 720p 60p video. It works pretty well but it currently cannot write mpeg2 so you have to convert to another format. The sad thing right now is that for the one market that would want this the most (weddings) would have no logical purpose to use it right now because it is very slow. I managed to get the rendering faster but still this is almost useless right now for hours worth of footage. I'm also not even sure if I recomend doing this anymore anyways since you would end up encoding your video multiple times. Who knows maybe Cineform will add this feature in the future so this is done in the background inside your NLE. |
For me: 1. Capture m2t. Place on timeline 2. Cut segments of unwanted footage from timeline, leaving me with a non-sequenced rough cut. (sequenced if shot in sequence) 3. Use GearShift to convert those segments to either CineForm or 4:2:2 YUV. If I'll be editing the project on a slower laptop, I'll convert to DVproxy with color mod for 709 vs 601. 4. Edit complete with HD title sequences, etc. 5. Replace DV Proxy or CineForm file with 4:2:2, or replace DVProxy with m2t, depending on destination. If it's going to HDCAM, I replace with 4:2:2, if it's going to DVD, I replace with m2t. Render, output, done. In this process, it's part of the conversion to go to 60p from 60i, if it's going to 720 from 1080. Otherwise, I merely convert the 60i to 30p. Then it's just a blend or interpolation of the fields. |
But does it make you want to throw up?
In response to the original question, I have shot with a variety of film and DV cameras over the years, principally PD-150 and Canon XL1 on video and Arri SR2 on film, though also Panavision Millennium and Sony Z1.
For what it's worth, I think the HD-100 (which, as of a week ago, I own) is much closer to a 16mm experience than any other video camera currently available in the price range. This is principally because of the lens. I'm well aware of the Chromatic Aberation issue, not to mention the split-screen effect (from which my camera also suffers - hmmm), but I'm still delighted with (by?) it. Why? Because it makes me want to go out and buy a tape measure and a light meter and remember the days of shooting on a wing and a prayer ... and not really knowing if it was in focus and correctly exposed until several days later ... and using my eyes, rather than a monitor ... and some intuition ... oh, and some testing beforehand ... and actually thinking through what the scene is about emotionally. And now I want a proper dolly that takes four people to lift, and some HMIs for night shots, and worrying whether the jenny's going to be audible, and whether we're going to need insect repellent, and what about the permits, and can we live without a script supervisor, and can I get a boom in there, and are the actors going to turn up, and what is the scene actually about emotionally ... And, yes, it is about the lens, because for all its shortcomings, this is the real thing ... you actually have to think about whether its in focus, and frankly who cares whether there's a purple / green thing going on around highlights, and yes it not so much breaths as hyperventilates when you pull focus, but it feels right. I guess I'm trying to say that I'm in love - not with a camera but with the rediscovered idea of being so nervous before shooting that I might have to throw up ... and the elation of capturing a look ... a moment ... a happy accident. And being prepared to put myself through hell to achieve it. Or not ahieve it. Because there's always the spectre that when you sit down to edit, you discover that is was all boring ... and flat ... and not what you meant. Because the scene was about something else emotionally, and you didn't find it. Or perhaps it was just a bad scene. But then again, maybe not ... whatever, it's really not the camera's fault. JVC's brochure makes a big thing about this being the camera for every purpose. This is utter nonsense. I've shot weddings, and this is simply not the right tool. This camera needs light - lots of light to avoid the split screen thing - and time. If you want to get something half-way decent (or better) on the hoof, get the Z1. If you want to save thousands of pounds / dollars / ringits in stock and processing, but take a few days off your life expectancy every time you switch it on, get the HD-100. Actually, get the Z1 - it's a lot easier. Oh, and don't listen to me - I'm new to all this, and it's late ... |
1080 24 is already on the Liquid timeline. We just can't capture it...
| All times are GMT -6. The time now is 08:00 AM. |
