If you are talking about capturing the uncompressed signal from the GY200's analogue component output then you will need both a very large drive (750 GB to 2 TB, depending on project specifics such as length of footage and whether it is 8- or 10-bit uncompressed) as well as a capture card (Kona, DeckLink, etc) or other I/O device (Aja ioHD). |
In my experience, the negligible performance boost of eSATA does not make much difference (for the price) in capturing/editing/daily use (especially when you factor in buying another card and taking another PCIe slot.) Where these discs shine is in large file transfers, the larger the transfer the greater the performance increase. Firewire also has the advantage of daisy chaining, something you cannot do with eSATA. If your controller has 2 eSATA ports you can hook up 2 eSATA devices. There is one exception to this which is called multi-lane eSATA, these cards have port multipliers (usually by 4) and can be used (depending on the manufacturer) to connect multiple drives via an octopus like cable to one port or with some external raid arrays you connect one multilane cable and then inside the raid array it breaks out into multiple connections. That's what I know but if you do a quick search on eSATA, i am sure you can get gobs more info with specific data numbers. |
Of course, you make the very good point about the cost:performance ratio. It depends on whether you will experience the full performance of eSATA or not. My .02¢ for Terry is this: if you are working with HDV or even DVCPRO HD (720p) then FW400 drives will be fine. When and if you step up to working with uncompressed 8- or 10-bit 1080 HD footage, then you will be in a different weight class which will require more power (all around). |
Mike- You make a compelling argument. I have only 1 HDV cam (at this time) and use either DVCAM or DV on my other cams depending on what i am working with. I typically, edit off my four 1TB internal Hitachi Drives (all set to SATA 300) for my own projects, my externals are for client drives (drives supplied by clients that they take back), website and doc files, and backup. When i bought my first quad (USB 2, 1394a, 1394b, eSATA) interface Lacie, i tested editing on it for a month hooking it up via firewire 400, 800 and eSATA, and I finally settled on FW800 for daisy chaining capabilities. I did not see a noticeable difference in editing via the 3 connection types, but I was not editing uncompressed...so it would depend a lot on the workflow. I do see a huge difference between editing on the external client FW800 discs vs. my internal SATA II drives. And would not go back to PATA no matter what. For the external drives though, you add up the cost of drive, controller card and PCIe slot limitations on most computers, and it costs you more than you gain (my opinion) unless you are doing backups.
What i would really like to see is eSATA controller cards with more ports or motherboards with more PCIe slots (without sacrificing other PCI access) or a mulit-lane controller at a lower price point (or better yet on the MB) maybe hooked up to an eSATA hub. That said, I have edited 7 cam edits on an external FW800 drive with an additional 4 tracks of PSD overlays and it performed fine. I love eSATA and if I could get all my ext drives to be eSATA that would be awesome but, for me, it goes back to available slots and controller card limitations. |
Hello everyone!
Thank you all for your feedback. I now have decided on either: LaCie | 1.5TB Big Disk Extreme+ with Triple Interface | 301200U Or: LaCie | 2TB Big Disk Extreme+ with Triple Interface | 301201U Really the difference is pay $300 for 2TB or $200 for 1.5TB. I honestly can't make the decision. I'd rather save $100 but would hate to be short in the end. I don't really know that I will be storing this much footage on this hard drive. I will be rendering from tape to an editing system then saving the useful clips and video progress to the external hard drive for later use. Bassically I just need it to store my works in progress on. Terry. |
In your original post you were concerned about security - now you seem to throw your worries out the window... what's gonna happen if your drive crashes?
Both of your choices are RAID 0. I hope you're not going with the Lacie just for the sexier look; the WD I recommended looks bulkier, true... but it's configurable as RAID 1 and it's less expensive, too. Did you know that all Lacie makes is the enclosure? Chances are, the actual drives are the same Western Digital drives inside the Lacie box. Good luck! You will badly need it if you work without backup. |
Just another sign it's a good choice.
It's available in lots of other places. |
Well I found it here for $225 but I've never heard of that place.
WD 2TB My Book Studio Edition II - CompUPlus Direct |
I've said it before, I'll say it again:
Make sure if you buy a WD hard drive that it doesn't spin down when not in use. On the WD's, this is NOT user controllable and can result in real workflow problems during playback. I own a WD MyBook and use it ONLY for DVD image output and miscellaneous files because waiting for drive spool up has ruined several print to tape outputs on my system. Other than that, it's been solid but it's affect on my workflow does not offset the lower price. Of course, your mileage may vary and I DO earn a living at video so I'm less concerned with saving a couple of bucks and more concerned with workflow. |
As far as I'm concerned, the fact that WD drives go to 'sleep'... it's a MAJOR PLUS , because I often times leave my computer to render overnight - and the drive(s) will stop spinning shortly after the render is over. Actually this is one of the biggest reasons I use exclusively WDs, both large and small/portable (bus powered): they all run cooler than every other drive I tried, and the big ones go to sleep. I am really curious what happens in your edit bay; when I go to my PC in the morning, all I notice is that I have to wait 3-5 seconds before I can access my files on those drives. If I look at the content of the drive (in Windows Explorer), it shows all of the files, including those created just before the drive went to standby, so if an application needs to access them, they report 'present', the application should just wait a few seconds to access the actual file... |
Ervin: I routinely have media spanning several drives - project media usually resides on a dedicated drive for THAT project and some of my "usual" items live on drives that are constantly attached to the system (FCP6). If on a long form project, the WD spins down, when the timeline gets to the point where media is required from the WD, I get stalled playback, thus ruining a Print to Tape. Therefore, I use only drives that don't sleep in my edit bay, or more specifically, drives that I can CHOOSE to make sleep or not. IMHO, drive sleep should always be a user choice, at least on drives intended for pro or semi-pro use.
Not saying everyone should adopt my methods, just saying drive manufacturers should give US the choice (which virtually every OS does - don't understand why manufacturers insist on negating the OS). |
| All times are GMT -6. The time now is 10:33 PM. |
