-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   No DVHS Device in panther (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/17551-no-dvhs-device-panther.html)
Bernard Ryan November 24th, 2003 10:48 PM
I can't capture in VirtualDVHS or DVHSCap under panther, when i reinstalled Firewire SDk18..
changed channel to 63.. no luck
any clues on getting it to see camera
bernie
Frederic Lumiere November 25th, 2003 04:08 PM
Try pluggin the camera on a different firewire port if you have or on top of the chain if you don't.
Panther, somehow doesn't like it if you plugin your camera in a firewire device vs. port.
If none of this works, unplugg all devices and plugin the camera only, then add devices one at a time and see which one takes the camera offline.
If you have only one firewire port, I highly recommend buying a card to ad another one dedicated to the camera.
Bernard Ryan November 28th, 2003 09:55 PM
Still no device.. decklink conflict ??
tried pulling all out all plugs, re install, different machine..still no luck..
Is there a set order to install SDK18 or is my Decklink card interfering ??
any other ideas ? or has anyone had problems before ?? and how did you fix.
(DP1.42 panther)
