Compositing the Program Stream MPG in AfterEffects
Bluescreen work is the best when compositing from the original source.
Simply use CapDVHS to capture from FX1 camera, and click "Output PS (program stream)" in CapDVHS's options. AE 6.0 can then import the resulting 1080i mpg files. HOWEVER, if you render these files out to Aspect HD AVI and play, you'll see a strange uneven motion - about 1 "frozen frame" glitch per 1/2 second, I think. Does AE 6.0 even understand how to reconstruct long GOP mpg's? |
| All times are GMT -6. The time now is 05:43 AM. |
