Working with multiple external drives on MBP
I'm starting a new project which is bigger than anything I've worked on before. The end result will be a 1.5 hour DVD and HD download. I live/work on the road and edit with a 17" MacBook Pro with a 1TB Lacie rugged external drive. That drive is already getting close to full and I'm only a quarter of the way with filming. Since I'm restricted to working on a laptop how will I work with multiple drives if I only have one firewire port? Will I be forced to use USB drives?
I film with a Panasonic GH2 at 720 60p and log and transfer to Apple ProRes. Thanks for any help! Alex |
You can daisy chain Firewire drives -- I have three attached to a single port as a matter of course. If you have a drive that is FW400 make sure it comes 'later' than the FW800 drives -- I believe the system will slow downstream of a slower connection. I can state though that my chain of FW800 drives maintain their full speed even when my slower FW400 drive is attached to the end of the chain ... I can't test my advice as the FW400 drive is the one drive I have without a second port, so it is always the end of the chain.
Cheers, GB |
I have been using the NexStar 3 HDD enclosures. They provide USB2, eSATA and Firewire 800/400 connections. When a HDD fills up, I swap in a new one. I have had now problems with daisy chaining Firewire drives.
For eSATA I have a Sonnet Expresscard dual port eSATA card for my 17-inch MBP. |
I found this Nitro AV 8 port Firewire 800 hub that eliminates the need to daisy chain. It's $150 but might be worth it to maintain speed to all your drives.
I use one of these. It has multiple interfaces and is safe when formatted correctly.
OWC Mercury Pro Qx2 4-Bay RAID 0/1/5/10 eSATA, FireWire 400/800, USB2 Desktop Removable Bay Storage Solution - up to 12.0TB Good Luck! Dave |
An expresscard with two firewire ports will give you a total of three ports.
Good Luck! Dave |
| All times are GMT -6. The time now is 07:47 AM. |
