Jvc Gr-pd1
Hi all,
I just bought a JVC GR PD1 (yap, in europe we still get the chopped-down version of the HD1...) and I started importing clips with a Mac using iMovide HD (5.x). What I can't figure out is why shootings I did at Hires (25p) resolution are played back at twice the speed. Can it be because the camera is being read at 50p instead of 25p? Do you know if there is an oft-the-shelf software package that handles the GR-PD1 transport stream correctly? What would be my editing options? Thanks in advance, Hugo Pinto |
Why do you call it chopped down ? In America we get 1280x659 pixels and thats almost the achievable limit of the 720p format. In Europe the 625p format is almost the 1280x659 pixels that you actually get even in Europe so what is the difference? Maybe its your television that is chopped down but your computer monitor should be able to display the full resolution
Chopped down...
Well,
I called it chopped down because the GR-PD1 (PAL) always outputs in 720x576, whether it's in Hi-RES, PS50 or DV. The main differences are: HI-RES: 720x576 with 1280x659 effective CCD pixels, 25p PS-50: 720x576 with 941x485 (16:9)/839x576 (4:3) effective CCD pixels, 50p DV: 720x576 with 839 x 576 effective CCD pixels, 50i So the output is always PAL-compatible resolution, which makes the PD1 a good (but expensive) choice to shoot progressive SD. Hugo |
So it's not really an HD camera? That sucks big time.
First of all when the GR-PD1 was introduced there was no market for an HD camera in Europe. If HD was offered people would simply not buy it because they were not yet ready for it so the marketing trick is to rebox the camera and sell it as a progressive scan camera thats meets the PAL 625p specification. This camera is sold as having the capabality to display all 625 lines of resolution but the PAL specification only requires that 576 of 625 lines need to be displayed. So doesnt that tell you that the PAL specifications are being exceeded? The trick is finding a device that will display all 659 lines of resolution and if you have a halfway decent computer monitor you should be able to display 1280 x 720. Also if you had a PC instead of a MAC you would have installed an HD capture device as software that came with the camera. But you only find out about the HD capture software after JVC has your money and you can't return the camera without paying a restocking fee. Imagine that a consumer wanting to return a camera because he got more than what he paid for LOL. But thats the consumer for you and he has his silly reasons because he thinks that high definition is not compatible with PAL and high definition is no good because it shows the wrinkles . Well 659p is halfway compatible with 576p and halfway compatible with 720p. Also JVC sells a weird 1250i television that upconverts 625i and 625p to 1250i or 1500i. So maybe now you can stop worrying about conforming to some PAL specification which is a straight jacked that the camera will never conform to and really start to exploit the high definition capabilities of your new camcorder. And stop listening to those JVC reps in Europe who only tell you what you want to hear and who only want to hold you back.
Ok,
I'm amazed. It seems that the transport stream coming out of the camera is 1024x576, which can easily upscale to HD. So I definitely take back my "chopped-down" comment (and feel a whole lot better for it). Unfortunately, I have another problem: I'm using MPEG Streamclip to demux the transport stream to an .m2v. However, the only format Streamclip does not propose to scale the video is 720x576, so I assume that that's the format Streamclip is recognizing the .m2t. Do you guys use any other demuxing tool that may take advantage of the full stream? Am I doing anything wrong? Thanks in advance, Hugo Pinto |
The situation is changing rapidly (actually has been for the past 16-18months!!) and appz such as Womble, TMPGEnc V3 XPress are now better able to handle this stuff... If you're more serious, I'd suggest you get a fully featured NLE - like Vegas... TMPGEnc V3 XPress has some pretty cool filters that come in handy with HD10 chroma noise, so it may be of some extra benefit to you. BTW, there aren't many programs that "recognise" HDV *.m2t You may find changing the file extension from .m2t too .mpg allows more players and programs to work with your clips. Only a hand-full of NLEs are capable of reading HDV *.m2t captured directly from a HDV camera. |
Hi, another question about the PAL GR-PD1.
A few months ago, I was able to use it for one day. I tried the 30p mode, but although the image looked great for SD, it had an intense motion flicker. Not smooth at all. It was very hard to shoot some decent footage with nice smooth motion, even when we set the camera on a tripod. It reminded me of a 15fps internet-webcam. I have little experience with progressive camera's, but could the motion flicker be a result of the fact that PAL is 50i, while the camera seems to capture 30p. I know 25p is suitable for PAL, and 30p is better for NTSC. *edit* Just found out that the PAL version actually is 25p. Probably it is just my lack of skills then ;) |
There is no 30p mode on the PD1. You must have been in 25p mode with a high shutter speed.
Hugo Pinto- "I'm amazed. It seems that the transport stream coming out of the camera is 1024x576, which can easily upscale to HD. So I definitely take back my "chopped-down" comment (and feel a whole lot better for it)." I have read this befor and am puzzled by it. I asked Ken Freed of JVC directly and he stated all output from the cam is 720x576. The 1024x576 number is the proper pixel output for 16x9 image. Where are you reading the pixel resolution? Inside the NLE? How does the 50p mode read out? Is it 720x576 or is it expanded as well? |
Hugo,
We got off topic; why don't you re-post the editing question on our HDV editing board: http://www.dvinfo.net/conf/forumdisplay.php?f=63 heath |
I would say his best source of reply would be in this forum. A cross post never hurts especially if it is invited, but very few of the general HDV users have more than a brief rememberance of these cams. Especially the PD1!
His first question was related to editing, hence the link. But I think we should keep the majority of this here, because of the discussion.
heath |
Yes, I have also seen that the PD1 has PAL-SD, so 720x576. And yes, there have been consequent rumors that the material is downpatched 720p material.
More important, the material can be blown up to 720 25p in a nice way. I tend to do that, by capturing the material with the JVC capture tool, and then I convert it to a 720 25p intermediate (either Cineform oder also Canopus HQ). Works fine so far. |
I had the same problem with my PD1 but I use a pc not a mac.At the time after much searching no NLE's are aware of the PD1 25P mode. Sony Vegas 6c is the only software I'm aware of that has resolved the problem.
Well, I also use a PC. And as far as I have seen now, both Edius and Vegas 6c are able to handle the PD1 material in a good way. So, no issue here.
The new MSP8 supports the PD1, too. However, tests have shown me that the capture utility in the MSP8 does not work fine. To capture with the JVC utility works better. Also in Vegas, I tend to capture with the JVC utility, and convert the material to either the Cineform Intermediate, or the Canopus HQ intermediate, using gearshift (I have both codecs on my PC). |
| All times are GMT -6. The time now is 07:12 PM. |
