-   JVC GR-HD1U / JY-HD10U (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/)
-   -   HD1 and HD10 discontinued? (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/56600-hd1-hd10-discontinued.html)
Dave Ferdinand January 25th, 2006 09:38 PM
Yes, yes. I knew about this but forgot! It's true, you can check what shutter speed it is in and same with aperture but you can't really lock both of them at the same time. I will try to do the sports mode + AE thing to see if it works but I think the only way to have control of both settings would be to choose one and lock the camera on it and then use ND filters to control the other, but that's hardly has versatile and fast as messing with full manual controls.
Ken Hodson January 25th, 2006 10:37 PM
True, it is not a run and gun cam. But if your a filmaker in the classic sense where most all shots are locked down and composed, it works well. Very well infact.
The point is, depending on light levels (straight through or ND filter reduced) the cam will settle on a shutter speed. Then you just have to adjust and lock the shutter. If it is more of a movement shot it can be better to lock the shutter (esp. if you want 1/60th) and let the auto exposure do its thing or reduce the light with ND's untill the exposure no longer pumps.
But alas I agree if they just offered the simple ability to lock the shutter at 1/60th (instead of only at 1/250th in Sports preset) they would have maintained a much bigger fan base for the cam and hence the HD100 that followed. A pissed custommer never comes back. Just ask Heath!
I still pray that someone will hack the firmware and offer a version that switches the 1/250th Sports mode to 1/60th. If they find away to drop EE on the HD1 as well, indi filmakers would scoop them up of ebay.
Ken Hodson January 25th, 2006 10:44 PM
I still pray that someone will hack the firmware and offer a version that switches the 1/250th Sports mode to 1/60th usefull mode.
Ken Hodson January 25th, 2006 10:49 PM
If anyone has any tricks/solutions to maximizing shooting with these cams, I highly encourage you to speak up. This forum especially, considering the agressive nature of the early days of the forum where these little cams took the blunt of all those who hated HDV, could use a little community. If you have found something that has given you great results please share.
Graham Hickling January 25th, 2006 11:16 PM
What Ken just said ... and also, someone mentioned dealing with the HD1's EE in post. I'd be interested to hear more about that.
