-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   Sony to license XDCAM EX file format to JVC (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/130685-sony-license-xdcam-ex-file-format-jvc.html)
Johnnie Behiri September 12th, 2008 09:51 AM
Sony : Sony to license XDCAM EX file format to JVC : United Kingdom
Geoff Murillo September 12th, 2008 10:13 AM
Great news!
Can't wait to see a JVC HD200-like camera with 1080p at a 35Mbps data rate.
Tim Dashwood September 12th, 2008 12:31 PM
This is new on the JVC website
KA-MR100G
http://www.dvinfo.net/conf/attachmen...0-kamr100g.jpg
http://www.dvinfo.net/conf/attachmen...-kamr100gw.jpg
Drew Cusick September 12th, 2008 12:41 PM
It looks so big, jeesh.
I dont have the hard drive, but would you say its pretty comparable to that in size?
James Espy September 12th, 2008 01:14 PM
I wonder if it only comes in the V mount?
Chris Hurd September 12th, 2008 01:20 PM
Photos and full copies of the press releases are right here on DV Info Net:
http://www.dvinfo.net/conf/digital-v...-xdcam-ex.html
Basically what this means is that all GY-HD200 and 250 series cameras
can now become Sony XDCAM EX format recordable, if you so desire.
Glen Vandermolen September 12th, 2008 02:50 PM
So the HD200/250 line will now be able to record at 35mbps? That's quite an improvement. You think the camera will now get a Silver rating by Discovery HD, just like the Sony EX line? Or will those 1/3" chips be a detriment?
Brian Luce September 12th, 2008 05:43 PM
Us HD100 and 110 guys get no respect. :(
Brian Standing September 12th, 2008 07:07 PM
How does it connect to the camera? Through firewire or HD-SDI?
Tim Dashwood September 12th, 2008 08:08 PM
Not according to the specs. 25mbps for 1080i from a HD200B. 19.2Mbps for 720p on HD200/250. It seems the camera's encoder is still being used.
For now this really just means you can record directly to XDCAM EX format on a SxS card. For now there is no image quality improvement over HDV.
68-pin multi-connector.
Steve Mullen September 13th, 2008 03:35 AM
"Future products from JVC will attach directly to the KA-MR100G."
At NAB I learned that the "components" on display in the booth could/would be assembled INTO future camcorders -- meaning the 200/250 series isn't obviously going to be the last camcorder ever built by JVC.
Which means hard-drives and solid-state can go from plug-ON options to built-IN functions.
So wait for NAB 2009 to see what can come of this relationship.
One has to wonder if JVC will function the way Toshiba did in the 89-91 period when Toshiba assembled a very nice PRO Hi8 camcorder using Sony parts. The problem was it was almost identical to the Sony.
With HDV, Sony and JVC split the market by 720p and 1080i. That worked nicely for both companies.
One option I could see is that JVC taking the lead in 1080p60 camcorders. This might work because JVC has, IMHO, always been the company that jumped first while Sony waits a year or two. There's a lot of infra-structure to get into place for world-wide use of 1080p60.
One can imagine a large European customer wanting camcorders in 2009 and finding Sony not ready and so they got the two companies together to build a 1080p50 camcorder ASAP. Don't rule-out a small lightweight unit for ENG. Think Sony Z7 and/or S270.
PS: Moreover, it seems JVC is using a modified version of Sony's ClearVid CMOS chips in it's latest consumer camcorder which nicely records both MPEG-2 or AVCHD.
Brian Standing September 13th, 2008 07:35 AM
Huh? I just own a measly HD100. But I've been pouring over the specs for the HD200 at B&H, and I don't see any such connector listed for the Input/Output connectors, just:
FireWire: 6-Pin (x1 Input, x1 Output)
Component Video: 3-BNC (x1 Output)
Composite Video: RCA (x1 Output)
Audio Input: XLR (x2)
Audio Output: RCA (x1) Headphone: Stereo Mini (x2)
Remote: DIN 6-Pin
Am I missing something?
Are we sure it isn't really just a firewire connection in disguise? That would make sense if it's limited to 25mbps XDCAM.
Tim Dashwood September 13th, 2008 08:36 AM
Originally Posted by Brian Standing (Post 934213)
...Are we sure it isn't really just a firewire connection in disguise? That would make sense if it's limited to 25mbps XDCAM.
You could be right. I'm just going by the specs but it looks like this device requires connection to the interface plate of the HD200/250 form factor. There must be some sort of direct internal connection since this recorder becomes a semi-permanent attachment to the camera.
I've had the AB plate off of the HD200/250 a few times and don't remember seeing any other ports in there but I did take photos of the procedure (to mount the L-shaped accessory plate) so I'll take a closer look.
Craig Yanagi September 13th, 2008 08:51 AM
Battery Plate Mount for KAMR100 XDCAM EX Adapter
The battery mount will be that of the camcorder you own. So, in the US the battery mount will be Anton Bauer. You can also purchase the IDX mount separately if you prefer to use a V-mount, or have large Sony brick V-mount batteries.
Craig Yanagi September 13th, 2008 08:59 AM
The multi-pin connector will serve as a multi-function connection. That's why a special adapter (KAUM100) is also being developed as the interface between the ProHD 200 series camcorders and the KAMR100. We're studying the best method to implement the adapter, and both the KAMR100 XDCAM EX dockable recorder and KAUM100 interface will be out at the same time.
Brian Standing September 13th, 2008 10:13 AM
Hi, Craig
Thanks for weighing in on this. Will there be any way to connect the XDCAM EX recorder to the HD100/HD110?
If not, will JVC be developing some kind of solid-state based recording solution for the HD100/HD110 line? Something along the lines of the recently-announced Sony compact flash recorder?
Marc Jayson September 13th, 2008 03:26 PM
KAMR100 IBC 2008 spinning around.
JVC HD-251 with SxS System on Vimeo
Craig Yanagi September 13th, 2008 04:14 PM
Originally Posted by Brian Standing (Post 934254)
Hi, Craig
No.
The only dockable solid state media recording device we have in development is the KAMR100.
Gavin Owens September 14th, 2008 05:17 AM
HD Timelapse
Will this system offer High definition Timelapse recording? I'm currently in the market for a solid state device and the abilty to record timelapse in HD is the deal clincher.
Gavin
Steve Mullen September 14th, 2008 04:44 PM
Hi, Craig
I hear the lust for something other than tape, but when one really looks at the COMPLETE workflow (cost and time), IMHO MiniDV tape simply can't be beat.
With Mike's ClipWrap you can import to FCP from a computer disk much like it were a camcorder disk or SxS card.
Of course, there is still the capture and conversion time, BUT were Mike to offer a version of ClipWrap with two new features you could have near "non-tape" experience.
1) Apple provides DVHScap as a kit that can be added to any program. So a tape import function could be added to ClipWrap fairly easily.
2) If anyone has used iMovie 08's HDV import function -- after firewire capture -- you see each clip in a light-table matrix and can preview each clip. Don't like it -- unclick IMPORT.
If ClipWrap had this, only the clips you wanted would be converted.
This gives the tape user the same kind of import experience as does the Sony Clip Browser. If you eliminate 50% of clips up-front you are a long way toward starting editing. And, you still have your Master tape for safe keeping!
Software like this could extend the life of the HD100 and HD110. For many who shoot 24p, these cameras are perfect.
Greg Boston September 14th, 2008 05:43 PM
I did... 2 1/2 years ago. XDCAM Optical was a no-brainer, offering cost per disc equal to other professional tape formats, faster than real time transfer, the ability to remove wasted shots from the disc while still acquiring, etc. The list goes on and on.
Used to it's full potential, there's no tape system that's anywhere near as efficient in both time and cost.
The cards are a bit pricey, but still offer the advantages over tape during the acquisition process.
And the NUMBER ONE REASON why tape isn't as good... You can't accidentally erase over your material with disc or card. It doesn't happen... period.
-gb-
Jim Boda September 14th, 2008 05:59 PM
Hmmm, that's a bit confusing. So, the initial option will be an XDCAM compressed version of an existing HDV compressed signal?
Brian Luce September 14th, 2008 06:06 PM
This is a big point for me; Archive. A point that gets lost IMHOP in all the tapeless excitement...
Craig Yanagi September 14th, 2008 08:14 PM
That's correct. The initial capability of the KAMR100 will be to take in the video signal via IEEE 1394, internally, and wrap the signal into an XDCAM EX file.
Gavin Owens September 15th, 2008 01:34 AM
Gavin
Any chance of an answer???
Craig Yanagi September 15th, 2008 09:17 AM
Gavin
The GYHD250 does not have time lapse recording capability. The KAMR100 does not have time lapse recording capability currently in its specifications.
Gavin Owens September 16th, 2008 12:44 AM
Pity....I was aware that the camera couldn't do so but I was hoping the next range of solid state recorders could provide a solution.Surely it's a basic need for cameras these days.
Thanks for you response
Gavin
