-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   use of SXS recorder on early gy hd series (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/234318-use-sxs-recorder-early-gy-hd-series.html)
Ian Skurrie April 29th, 2009 08:39 PM
Is the only reason that you can't use the docking plate KA-UM100G and the SXS recorder on earlier GYHD models like the 101 series that there is no provision for holding the plate on the back of the camera and if you could work out a way of holding the plate via a home made adaptor could you then use the SXS module??
Drew Curran May 21st, 2009 05:11 AM
Good Question. I also want to know this. Can anyone answer this?
Drew
Jack Walker May 22nd, 2009 11:14 AM
Here's the JVC page on the SXS recorder. It works on the HD200 and HD250, with differences. The information is in the specs:
JVC Professional Features page
Not clear if it would work on the HD110, but it is clear JVC does not intend that.
Note: It requires the adapter to put it on the HD200/250.
Ken Grohs May 26th, 2009 01:16 PM
Originally Posted by Jack Walker (Post 1146878)
It works on the HD200...
Note that it only works on the newer HD200UB and not the HD200U.
I know. I asked. I cried (well, almost...)
-Ken (owner of an HD200U)
Brian Standing May 26th, 2009 01:41 PM
I can't even tell how this unit gets its signal from the camera. I originally thought it was via IEEE-1394 (in which case it would theoretically work with the HD1xx series if you could find a way to carry/attach it.)
But it seems it taps into an internal (propietary?) connector on the HD2xx series somehow.
Trip Gould August 6th, 2009 02:28 AM
So, aside from the reliability of solid state vs. hard drive (i.e., firestore) does the SXS module offer any advantages over a firestore-type device in regards to bitrate or codec or image quality?
