LCD monitor HELP!
I just got my HD100 last night [stayed up 'till 1AM playing with it. However, I can't get the flip-out LCD monitor to work. What givse? The viewfinder works fine. I know there are about a million options and settigns for the beauitul camera, but I figured that when you open the door up, it would come on, like most cameras today. Am I missing something?
Yes, I'm in Camera mode (not VTR mode), yes the lens cover is off and the iris is open. I've tried adjusting the LCD brightness to no avail, and set the menu option for MAX. I've gone through every menu option I can think of and just can't get the LCD to work. Do I need to send back this wonderful camera that I've been wating 4 months to get? |
Press the DISPLAY button, for about 2 sec. It's on the top of the camera just behind the handle. That should toggle the camera between the EVF and LCD (see page 19 in the operator's manual).
Check page 27 of the manual, "CONTROLS, INDICATORS AND CONNECTORS". It explains how to switch back and forth between the LCD and VF. Use the 'Display' button.
Ah, Chris beat me to it... :-)
Simultaneous posts -- jinx!
Yes, I did hold the button for 2 seconds. I tried that 18 times! I think it is defective. Darn. If you think of anything else, let me know, otherwise, thanks for trying.
I had the same problem on one of my first HD100s that I took back. It worked for the first hour, and then the next day I turned it on and the LCD didn't work. I just wonder if that bad unit has been put back in rotation without being repaired? |
Looks like it's time to call your dealer, Troy! Let us know how it goes,
have you tried toggling the physical switch - it's just a pushbutton that operates as you open an close the door - maybe the contact's are dirty. otherwise it's back to JVC...
Hey all,
It looks as if I have the same problem. However, I have shot over 50 hours worth of footage before this happened. This is also my second time around with the HD-100. The first one worked for a few hours, and then I couldn't even turn on the camera at all, it just died. So I returned it, and got another new HD-100 (this one) and now the LCD screen is totally blacked out. I tried all the advice listed above, and nothing will get the picture back... The eye viewfinder works fine, which is good because I have a shoot coming up this weekend, and I don't have time to fool around with this crap. Man, for an $8000.00 dollar camera, I would expect much better than this. As you can tell, I'm a little bit upset about this... Thanks for listening. As you were. Michael |
Michael,
I'm sending you an email with contact info for the HD100 engineer in Toronto. I had this happen once too. It is probably a bad internal connection with the flip-out. |
Thanks Tim
Thanks Tim,
The contact you game me for JVC here in the Toronto area was really helpful, and actually gave me a call on my cell phone. Wow, what a nice guy! He also had nothing but great things to say about yourself and this terrific forum. I will be sending in the camera for the LCD service at the end of September, as I am too busy using the camera until that time. (And I can still use the eyepiece viewfinder in the meantime). He said I just might be able to get same day serivce depending on the circumstances. Ya know, it's funny, I'm so pleased with the preliminary service, that I've forgotten so far that I've totally forgotten (almost) about the fact that this is the 2nd technical problem I've had with the JVC HD100. (I should actually be really pissed... but I'm content because of the great service.) Thanks for the tip. Michael |
| All times are GMT -6. The time now is 06:30 PM. |
