WhitePaint <R> example m2t
A WhitePaint <R> example. WhitePaint <R> has the effect of white balancing against a warm card. The method is to white balance the camera and then selectively set the warmth (or pull the warmth out) of the resulting scene using the WhitePaint <R> menu setting. There is also WhitePaint <B> which does the same thing as white balancing against a cool card. WhitePaint settings adjust the overall look of the scene as opposed to the Gain and Rotation settings which will adjust CMYRGB somewhat individually.
Click here for wmv with titles and some music Click here for the raw Horse m2t to play with all the best and keep shooting! |
Much appreciated, Stephen -- thanks for sharing these with us!
My understanding is that white paint only affects when you're using auto white balance, yes?
WhitePaint does not work in FAW or "full auto" mode.
The proceedure is to white balance first with the Auto white Balance button and then go into the menu and adjust the WhitePaint <R> or <B>. If you auto white balance again the setting is lost (automatically reset to "normal") and you'll have to go in and make your WhitePaint setting again. |
| All times are GMT -6. The time now is 11:22 PM. |
