No time code and no audio
I've had my camera since October and on our first shoot, we ran into several instances where we lost time code. When we reviewed the footage, there was video but no audio. It happened 3 times that weekend but hasn't happened since. Any suggestions?
Also, does anyone know if there is a way to adjust colors in the VF or LCD. I really think that the colors are so off compared to a monitor. Maybe I have a bad VF? Does that seem to be a problem for anyone else? Thanks everyone for all the tips, this is my first time writing in. Brian |
Hey, there is an idea for a firmware upgrade...JVC are you listening? Just like almost every (even consumer) display the VF and the LCD of the HD100 should have adjustments for BRIGHTNESS, CONTRAST, HUE & COLOR. |
No Audio again!
Well, as luck would have it, a few hours after I posted the thread about no time code and audio, It happened to me again. It's been fine for a month or so and just now it did the same thing. I think time for service. I can't believe it, it's barely been used and problems, problems, problems.
Brian, I have a firmware update that fixes the non TC and audio after rec-stanby-rec sequence. My delaer sent it to me to fix this and some other issues caused by the recorder. Maybe you should talk to your dealer and request a firmware update. I can send you mine, but I have a HD101E PAL version and I don't know if it works on NTSC models. Also, I advice you to get it from an official source... or you could lose the warranty.
Thanks for the info, I will check with my dealer about the firmware upgrade. I was almost thinking that it could be a problem with the head alignment.
Brian |
| All times are GMT -6. The time now is 05:48 AM. |
