Dr-hd100-80
I am trying to read all I can on this new hard drive recorder, and from what I gather is if your shooting HD and you want to down-convert to SD to get the most out of your video source, this device is pointless. Is this true or am I missing something?
Hi Rod,
The HD100 does not offer a live downconversion to DV from HDV over FireWire. Therefore it's not possible to record SD on the FireStore while recording HD on the camera. This isn't a limitation of the FireStore; it's a limitation of the HD100. The Canon XL H1 has the same limitation. Sony HDV camcorders will do a live downconvert to SD over FireWire. Too bad it's not a standard feature among all makes and models. |
Rod, The HD100 is sending HDV to the firestore, and that is what it is saving. To say that this is of no use for a project that will be DV in the end is not true. Capturing to HDV first, doing your editing in HDV, and downconverting to DV for the final file will produce a better looking finished product than doing the whole thing in DV.
Plus, later if you ever want to publish your work in HDV, you will already have it. |
What he said. |
http://www.aja.com/products_converters.html
How about any of these?:
http://www.aja.com/products_converters.html |
| All times are GMT -6. The time now is 10:33 AM. |
