@S.Mullen
The "mandate" to digital TV. WTTW is one of the TOP PBS stations and a big supporter of JVC technology top to bottom. There content is first class. P.S. If my opinion doesn't match yours, then it doesn't match yours.... |
However, unlike the JVC HD100, neither broadcaster uses the "repeat frames" feature of MPEG-2 to allow film-source pictures to be sent only once (and the receiver to repeat them to perform the 3:2 pulldown). That means that when ABC broadcasts a 24 fps movie or a prime-time show, they're still sending 60 progressive frames per second and wasting lots of bits on needless redundancy. ABC's "real" bitrate for film-source material is about 12 Mbps. (Compared with the JVC HD100, which has a real bitrate of more like 19 Mbps since the HD100 uses the "repeat frames.") Still, I agree that those 12 Mbps from ABC look pretty nice as you pointed out! So I think a lot of it has to do with the sophistication of the encoder. |
I would like to see JVC promoting this new codec chip more and more into the future. We need comparison samples, something visual for the non technical to understand what its all about.
I have been aware for a long time not all MPG2 encoders are created equal but I know for certain others many do not realise this. First generation DV was pretty much all the same camera to camera (purely in encoding quality), one standard VHS recorder resulted in basically the same result as another but this is not true of MPG2 and other MPG variants like MPG4 etc The general community need to be educated on this. Not in forums like this where the fact people are able to interact in a relatively technical way leads itself to being more technically aware of the products on the market, but most videographers I know hardly know a KB from a MB. Quite rightly so too, they are more interested in the subject than the equipment specs |
I've been thinking more about GOP length and "quality." I think quality is directly related to two very different types of artifacts:
1) MPEG-2 Motion Blocking Artifacts from rapid motion 2) MPEG-2 Mosquitoe Artifacts from fine detail Therefore: The image quality (MPEG-2 mosquito artifacts from fine detail) of inter-frame codecs (HDV) cannot be inferred from data rates unless you also take into account GOP length. With Constant Bit Rate (CBR) encoding, increasing GOP length increases image quality because the P- and B-frames increase codec efficiency at a given data rate. MPEG-2 Motion blocking artifacts, however, will be greater because I-frames are less frequent. Conversely, the shorter the GOP, the fewer the motion blocking artifacts because of the more frequent the I-frames. The shorter the GOP, the less efficient encoding will be at a given data rate and therefore the more fine detail mosquito artifacts. |
In LV during the day, PBS HD is unwatchable. But, during Prime Time it gets a "bit" better. Yet the second SD channel continues. Which makes me wonder: 1) Do they rebalance the HD/SD data rates in the evening? 2) Do they run 2 sub-streams during the day? I heard a lot of talk at NAB that even some CBS stations would very much like to broadcast 720p60 at about 14-15Mbps which easily gives them 3-4Mbps for a sub-steam like weather and news which is a second revenue source. Of course CBS, the network hates this idea -- unless it buys CNN in which case the second stream becomes VERY valuable! Likewise, NBC would benefit from OTA CNBC in the day with MSNBC at night. Since DirecTV cuts 1080i off at 1280 there would not be much resolution lost. 72060 really makes far more economic sense than 1080i. |
Don't anyone get me wrong, I've had signal breakups on ABC as well, but I think that has more to do with where you and your antenna are located in relation to where the broadcast towers are. All I know is, the super bowl on ABC looked spectacular and relatively artifact free which was a first for my eyes.
One other thing on films being shown on national networks I found interesting. I was capturing the beginning segment of Terminator 3 on my home system with this neat little external USB HDTV Tuner I have. I took just a few seconds of it to work and converted it to uncompressed .mov to look at it on our fcp 5 system. I realized there the movie clip said its source was 24fps! Anyone here look at the quality of D-VHS? Thats a 14.1 bitstream at 1080i. How does it hold up by comparison? |
I could be wrong on this because I haven't checked it out in detail, but I believe this is how it works. So it's not the case that a 12-frame GOP just replaces one I frame with a P frame -- it also replaces two bastard B frames with legitimate B frames that are each the children of two parents. On ATSC HDTV, of course, they use 15-frame GOPs or 30-frame GOPs or whatever, but the broadcasters also never send *closed* GOPs. The broadcasters have the advantage (unlike the HD100) that every B frame they send can be bilinearly predicted by the most-recent-past and most-proximate-future reference (I or P) frames. |
The frames are encoded with the I frame first and then the P frame(s) (because they depend on the I frame) and then the B frames (because they depend on the I and P frames). So the "encode order" is: I _ __ __ P __ __ _ B1 B2 _ B3 B4 The Closed GOP means the final two B frames are encoded only from the past frames. So these are the "bastard" frames. The "transmission order" is based on the order we need them during decoding. This should be: I P B1 B2 B3 B4 I P B1 B2 B3 B4 |
talk about a dysfunctional family.
[QUOTE=
Anyone here look at the quality of D-VHS? Thats a 14.1 bitstream at 1080i. How does it hold up by comparison?[/QUOTE] Hi Mark, The DVHS HD recordings can be at a bit rate of up to 28 MB/Sec, and they look stunning. We use DVHS machines frequently on demos of our DILA HD projectors, on very large screens. |
I think that's not quite right. The coded order (or "transmission order") of the frames in an HD100 GOP is IBBPBB. If we put in the temporal reference (which shows the display order), it becomes: I2 B0 B1 P5 B3 B4. So the display order (which I referred to earlier as "temporal order") goes B0 B1 I2 B3 B4 P5. Quote:
One of the issues is, we are in sort of an inbetween time, along with the mandate should come a converson to h.264 which in theory, should alleviate many of he bandwidth problems and allow for sub channels without affecting the main channels quality. We're not there yet, probably won't be until the very latest possible moment allowed by the FCC. The Europeans are actually way ahead of us on this. (use of h.264).
| All times are GMT -6. The time now is 07:15 PM. |
