Gy-hd100 Audio
Can the camera's audio record on both L/R channels from one input source?
Thanks. |
Yep...
(Do I need to explain how?) Input in channel 1's XLR and set the switch for channel 2 on 'same as channel 1' Done... |
best resuts in a 12 dB
Thanks alot guys.
Oscar you suggested set it at 12db. I'm going line not mic. Would the 12db setting apply to line or mic? |
-12dB is the reference level the cam works at. You can also set it to -20dB.
It affects mic & line. Mark |
| All times are GMT -6. The time now is 08:27 PM. |
