-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   OT: Huey, if you don't have one, you need one. (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/80412-ot-huey-if-you-dont-have-one-you-need-one.html)
Bill Ravens November 28th, 2006 11:28 AM
it's, fundamentally, a screen spectrophotometer that maps detected color swatches to an ICC profile, which you then load into your monitor profile to give you corrected colors on the screen.
Stephen L. Noe November 28th, 2006 12:19 PM
Originally Posted by Mark Silva
so basically this little device will calibrate a crt or lcd perfectly?
thats amazing for 90 bucks.
How does it work?
would it work for calibrating a sony pro video monitor?
It's not "perfect" but it is pretty close. When I do a blue balance the SMPTE color bar chart, the cyan and magenta are pretty close and far closer than without the calibration.
I don't know about a sony pro video monitor because it's typically connected via component or Svid so probably not. The Pantone device calibrates your VGA/DVI connected LCD/CRT monitor.
Jack Walker November 28th, 2006 12:36 PM
Does this work for an LCD television screen as well?
It seems that Colorvision sells two different versions, one for computer monitor and one for tv screen -- and the Colorvision vision products are both much more expensive the the $79 one talked about here.
(I read in one of the linked reviews that Pantone originally had a deal to work with Colorvision but the arrangement was abandoned and the new relationship was developed.)
Bill Ravens November 28th, 2006 12:49 PM
TV screens, by definition, are hardwired to sRGBcolor mapping.
Daniel Patton November 28th, 2006 11:34 PM
Originally Posted by Stephen L. Noe
A while back I picked up a Pantone Huey because my LCD's were all of the place for color correcting my HD-100 footage directly on my Computer screen. The little device will send your LCD through a process that will correctly gray balance any screen and IT WORKS.
I know this is off topic from HD-100 stuff but the Huey is such a good thing I think everyone should know about it.
Regards,
Stephen
Thanks Stephen,
We have the Spyder and I'm real unhappy with the results, it's been a huge pain in my @$$. Worse, all our developers/monitors are way off, and not in sync, so the same content looks different on every system. I'm more than happy to give the Huey a shot at calibration in our office.
William Hohauser December 6th, 2006 05:17 PM
The Huey is a nifty little contraption but the software is definitely version one. It can't do a two monitor system unless you trick the computer by switching your main monitor and then switching back. That will work unless the computer's video card won't allow two simultaneous calibrations.
It also does some strange things if you don't want it to continuously monitor the room light. I rather not have the device sitting around all the time. The update available on Pantone's web site seems to help a little but the software needs some fixing. The application preferences which didn't open in Mac version 1.0, with version 1.0.4 opens System Preferences which now has a "Huey" option. But you have to close the Huey application before the options in System Preferences will work. A little clumsy.
The colors do look a lot better but I'll stick with a regular video monitor for now.
Salah Baker March 21st, 2007 06:57 PM
Odd I have a Spyder 2 pro, and have done many, many, Calibrations on the windows side with it and have been very happy...
Hey Stephen :D
Miklos Philips March 23rd, 2007 03:48 PM
From the way it looks, I would spring for the PANTONE® Eye-One Display LT for an extra $70. The HUEY only seems to give you "basic" functionality. If you're serious go for the PANTONE® Eye-One Display LT.
cheers
