4:2:2 component out?
Hi everyone, I know this has been talked about before but I can't seem to find it under the search tab. Can someone explaint to me in a step-by-step nuts and bolts kind of way on what I have to do to shoot component out from my 110u, meaning what do I need to do that and what do I need to plug into what, and the pros and cons of this? Thank you.
You might want to start by looking at your options for device to capture the component signal like the AJA and Decklink products. The pro's of going component are that you bypass the HDV/Tape, no longer are limited by the 4:2:0 color space, can work in 4:2:2 as uncompressed or DVCPROHD, better for keying, color grading and post production. And if real lucky the girlfriends complaints are kept to a mimimun since she know you are now broke. Best case scenerio of course.
The cons are that you will pay the price to use the AJA / Decklink products, will need a fast RAID drive array if you should choose Uncompressed (more $$$), DVCPRO HD is at least another option shoud you want to avoid the RAID drives. I found the component to produce a soft and rather pleasing picture, well soft at least, the verdict is out on if it's all that pleasing or not. Is this any help at all? |
Thanks Daniel that helps a lot but now I have a few more questions. I checked on the Decklink site and a standard 10bit model only costs $300, and I don't think that's too much $$, however explain to me how this works exactly, does the Decklink go on a computer (laptop I'm assuming) and I have to have that computer plugged in to the camera as I'm shooting? Is that how it works? and where does the RAID drive come into all this, does that also go on the comp?? Or am I seeing this completley wrong. By the way I have a MacBook Pro, is that good/bad? Sorry if these questions sound pathetic I'm just not very bright when it comes to all this technical jargon and know-how.
Well, you are right on your way there, that line of thinking is pretty well spot on. And yes, the Decklink is attached to the computer and the camera goes to the Decklink. Think of the Deklink as a bridge to get the data over from camera to computer. The drives attache to the computer and store the data being captured by the Decklink. Simple enough.
Basic entry level price is around 1295 for the decklink card. Be sure you have compatible I/O with the card you're looking at. For example, the Decklink cards, typically, take HD-SDI input. The HD100/110 outputs HD component(analog). So, you need a converter for going from analog to digital HD-SDI.
http://www.mobl.com/expansion/produc...ion/index.html It's the way of attaching PCI based card into laptop. I don't have the product yet, but 2 slot chassis can fit 2 hard drives, stripped them to 0 RAID with one slot for PCI used for SATA RAID Adapter and the other PCI slot used for Decklink. But, to capture uncompressed 10-bit is not advisable in this setting because of the bottleneck. You need a powerhouse machine. |
I may be be wrong on this but I'm not sure this solution will work because the Decklink Cards are all PCIe or PCI X. Basic "Plain Jane" PCI slots are too out-dated and slow. |
Thanks guys. A real help. Decided that its just not realistic for me budget wise. I am getting ready to shoot a short although its close to being an hour long. Now i need to decide what is more essential the DR-hD100 drive or a Letus35HD100, although I hope to have enough $ for both I may have to choose only one. Anyway, thanks again.
If you aesthetically need the narrower DOF in your short, then obviously go with the Letus 35 and some lenses, if workflow is more important, I'd go with a DRHD100. Alternatively, buy the DRHD100 and see if you can hire the lens adaptor or vice versa for the shoot. (In generaly the HD100 seems a better purchase because it also enhances your kit for non narrative work.) |
I still don't get this.
How do I bypass the tape by going component? I would have to use something like DV Rack (which is Firewire only) for direct-to-disk, wouldn't I? Thanks for answers. |
Hey Jiri,
Both tape and firewire have HDV compression applied but the component out is prior to the cameras compressing the signal to HDV. Being that the firewire has this compression, that means that the DTE (Disk to Edit) portable drive solutions and products like DVRack have the HDV compression as well. It might save time as you avoid capturing from tapes after a shoot, but you gain absolutely nothing in quality. The only way to avoid a compressed signal is to go out the component jacks to a capture system (the AJA & Decklink products mentioned earlier) as uncompressed. This is a large data stream and so requires a drive array (multiple drives chained together). You could say both of these solutions are essentially direct to disk but only one "component", offers some (arguable) gains.] |
I know that it can go directly to FireStore hard disk but the colorspace is still intact in 4:2:0. I just want to have more colorspace like DVCPRO HD (4:2:2). I know it is still in compression, but is it possible go for this format or any format other than uncompressed? |
So, if I understand this correctly, outputting straight through component is like a direct-to-disk, hence used only in controlled environment? There's no benefit in capturing component from tape, right? Thank you all very much for answers!
1. deck may do some chroma smoothing that produces slightly more appealing look visiually. sony DVcam decks do this via SDI. can't say for JVC/sony HDV decks.we are talking *marginally* better or should I say different results. again if you go to DVCpro though, you loose enough resolution that I'd not really consider this, not to mention 14mb/sec vs 2.5mb/sec, almost a 5X factor. 2. if you need to push color correction, then capturing to 10bit uncompressed/lightly compressed might be an edge in finessing color correction. only something to consider once the cut is locked and you're just reloading a fine cut. |
| All times are GMT -6. The time now is 08:37 PM. |
