-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   Shooting Stock Footage (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/89259-shooting-stock-footage.html)
Dave Carson March 18th, 2007 05:24 PM
Hello,
I'm new here and just have a quick question.
I have a 110u.
I use warm cards and a circular polarizer.
Question:
For nature stock footage filmed in 1080i, what fps and shutter speed would you recommend.
This is for stock nature videography such as deer, birds, so on.
The reason I ask is looking at the best possible useage for editing, ie: slow motion, best colors, the "national geographic" look, what would the best method to sell be?
HD 1080i 60fps?
I need a standard that customers will know that I use.
Don Bloom March 18th, 2007 07:25 PM
The JVC HD110 does not shoot in 1080 anything - it shoots 720p and in order to shoot 60fps you must shoot in SD (480)
To shoot in720-60p for good slomo you must have the 200 or 250 series camera.
To try to lead you to a reasonable way to shoot what you're going to shoot I would shoot 720p30p and not use 24p as it would probably be to stuttery for nature type work.
Don
Tim Dashwood March 18th, 2007 07:36 PM
The "National Geographic" or "BBC" look would suggest film - typically Super-16. If that's what you want I would suggest 720P24 at 1/48th shutter.
IF you want slow-motion at 24P, then you might consider an HD200 or HD250 and shoot 720P60 (@ 1/120 shutter or 180 degrees.)
Tyson Perkins March 19th, 2007 02:17 AM
although footage can be upscaled to 1080i quite easily - and with great results
Dave Carson March 19th, 2007 07:38 AM
Are you sure no 1080i?
I have a hd110u which clearly has a setting for 1080i on it.
Maybe I can take a picture of it.
Bill Ravens March 19th, 2007 07:58 AM
are you sure you have a JVC HD110?
Sergio Barbosa March 19th, 2007 08:27 AM
Dave, your probably referring to a menu option that allows you to send out a 1080i signal from the component out, during playback. Being that it's upscaling the recorded signal, onto 1080i.
If you check the recording modes you'll see that only standard definiton and 720p modes are availiable.
Dave Carson March 19th, 2007 09:11 AM
Okay yes, I see that now, only 47 and going blind. It happens I guess.
I'm not the best videographer, I just retired and bought this camera to quiet a passion I've had for my life.
You know, in 200 years no one will remmeber any of us, but if they can watch what we film and see what we saw and see how the world has changed, then I'll have done my part.
So for a hd110u what is the highest def possible settings wise?
720p ?
Daniel Patton March 19th, 2007 10:17 AM
720p ?
Amen brother.
And yes, 720P.
