So whats up with the audio lag in final cut pro 6 has it been fixed?
Gary, what audio lag are you speaking of? I've not seen or heard of any audio lag on my fcp system editing HDV from the HD100. |
1) MPEG-2 IN and uncompressed OUT. 2) At the same time, MPEG-2's 4:2:0 color space is upsampled to either 4:2:2 (uncompressed video that is written to a file) or 4:4:4 immediately used by FCP. 3) If you choose 10-bit uncompressed video written to a file, the 8-bit baseband video is upsampled. Likewise, if you set FCP to 10-bit, 8-bit baseband video is upsampled. If you choose to convert after capturing MPEG-2 you dramatically increase the size of all source material -- yet no quality is gained. Whatever MPEG-2 artifacts you might think are in HDV, will be copied perfectly. Huge cost and no gain. Conversly, if you leave the MPEG-2 in a file -- nothing at all degrades. When FCP needs a video frame, it decodes the frame it needs to 4:4:4 uncompressed at either 8-bits or 10-bits. It makes no difference whether the mpeg-2 frame is an I,B, or P frame. All information needed to get an uncompressed frame is gathered and used. (Likewise, if you convert immediately after capture, each uncompressed frame is totally independent of its I, B, P nature.) So, it makes no difference to FCP whether it reads an uncompressed frame from a file or it reads an mpeg-2 frame from a file and decodes it. The frame fcp uses has exactly the same quality. No more and no less. All FX, CC, and even exports, are done -- as they must be -- on uncompressed 4:4:4 frames. When a frame enters the render/display/export engine, there is no history of what it was in a file. Or, when it was converted. In all cases, each MPEG-2 frame has been decoded exactly ONCE. And, no matter how many layers, when it comes time for export -- no matter if your source files are were uncompressed or MPEG-2, each HDV frame will have been decoded only one time. As the render engine works on images -- no "MPEG-2 errors accumulate" because everything in the render engine is uncompressed. When the final result of each frame is complete -- it is displayed and discarded -- never to be used again. Contrary to what many believe, the result is not re-rencoded to MPEG-2. It's tossed. Even if you force a render -- which with fcp's realtime ability you should not need to do all that often -- the preview files are never used for the final export. |
We're running FCP 5.1.4 with a Kona card now and our (more expensive) Avid gear is up for sale! It's the end of 8 years of pure Avid editing for me. This HDV1 thing is the straw that broke the camel's back here. These last two weeks have been my first time editing seriously on FCP and we're working mostly on HDV1 25fps material with great success. I made a wishlist over those two weeks of what I wished FCP would include to make it put it on a par with the Avid finishing systems I have used for years. I'm pleased to say that nearly everything on that list has been addressed with FCP Studio 6. For PC users the NAB announcement of the new Liquid variant with AJA Xena support is very good news indeed. |
MINI 35 Compact for 1/3" cameras with detachable lens
C like Compact
Image Converter for 1/3" cameras with detachable lens Use 35mm film lenses on your digital video camcorder to achieve better images in HDV format. Depth of field, focus and angle of view are virtually the same as with a 35mm motion picture camera. What's New ? - More light sensitive resulting from a new designed high quality relay lens - Compact and lightweight design - Competitive pricing - Prepared for P+S Technik Interchangeable Mount System (IMS) MINI35 C like Compact The new MINI35 Compact combines the market proven features of the MINI35 `400´ model with re-designed optical elements into a more compact and lightweight housing, especially for video cameras with a detachable lens. First time presented to the market in 1999, the MINI35 Image Converter became a successful product and a must-know tool to the digital film and video industry. The current technological development shows how important the 35mm format and its features are still to professional film production. Key Features - Optimized for 35mm film lenses - motion and still - Virtually the same depth of field, focus length and angle of view as with a 35mm film camera - P+S Technik Interchangeable Mount System available for shooting with Arri PL, Nikon, Panavision, Leica, Zeiss-Contax or Canon EF 35mm lenses - Industry standard 15mm lightweigth support rods accommodate popular matte boxes, follow focus units, and other professional motion picture accessories 22695 MINI35C Compact Image Converter for JVC HD-GY251 Incl. 1 side handle, provided for 15mm LWS rods, interface for 35mm bridge plate, prepared for P+S Interchangeable Mount System (add. order of one IMS mount neccessary) Click here for more info en specs. |
All that info is great (I'm the resident compressionist here at work and I understand your lingo) but I don't think it answers the question. Somebody with a mac/intel system that has a firewire port only for digital video capture of HDV to their local sata drive will not be doing anything uncompressed except export processing....correct? (and thats why it takes so long with such low bandwidth) |
How is the FCP 6 trim mode compared to Avid Xpress? I've tried FCP at the Apple store but don't have much exposure otherwise. I really do like AVid's trim mode but wish they were much more feature rich otherwise. TIA, Andrew |
Here is a link to the JVC Pro press page for NAB 2007 http://pro.jvc.com/pro/pr/2007/nab/default.htm Regards, |
shame
Craig Yanagi presentation at NAB 2007
Here you can find a video of Craig Yanagi explaining the difference between the JVC ProHD cams.
Adobe Creative Suite CS3 , Adobe AfterEffects CS3, Premiere is back to the Mac. DVRack is now "On Location". Adobe is committing to a true multiplatform release of all its tools. It will be interesting to see if On Location and Ultra will be included. AfterEffects CS3 introduces vanishing point 2.0 with exchange of 3D worlds from Photoshop CS3. Many other features, 3D text improvement, puppet pin tool which works equally well with pictures and drawings, native Intel support for Mac means that I can now scrub HD 1080p footage in AfterEffects in my laptop. The new Adobe Media Player allows you to play Flash files from the desktop, introduces the ability to include interactive elements that pause the movie, open subwindow and can connect to online information while the movie plays. Also, movies can cause automatic switching of skins in the player. Very, very nice. Reagarding codecs, this is not something from NAB but you should do yourself a favor and look at SheerVideo by BitJazz (http://www.bitjazz.com) SheerVideo is a lossless compressor that generates files that are less than 1/2 the size of uncompressed and retain all the color informaiton. In fact it's one of the best ways that I found to interchange information between applications while having the absolute guarantee that colors are preserved. Interestingly enough, it runs and plays faster than other uncompressed codecs. BitJazz has a free preview that runs for 20 days and the reader is free as well. At the optical/digital level Tiffen has demonstrated an impressive new software called Dfx. It has the emulation of all Tiffen filters by their "hardware" names, it includes the Rosco light gels again by name and it has listed a massive amount of GAM gobo patterns. You can take a picture via your digital camera and then apply the filters, light gels and patterns and come up with a new picture or use it to define the look of your movie in pre-production. This allows you to see the effects of any given Tiffen filter at home with all kind of pictures that you have. Very, very nice. |
-gb- |
| All times are GMT -6. The time now is 08:47 PM. |
