Sony M25U no letterbox
Hi this is my first post on the site. I have been using DVinfo.net for a year and all I can say is THANK YOU. All of my purchases have been based on what I have learned on the site.
I am looking to buy a Sony M25U deck to copy tapes (for clients) from my Sony Z1 and save my camera heads while sending 100 tapes a year to my computer. But I have read the deck will not downconvert using letterbox. Has any one found a way around this problem? |
I have one at 'work' and my own M15 and I think you're right.
The only downconvert options are squeeze (true 16:9) and crop, from memory the M25U will let you pan the crop downconvert. I couldn't really see much need for letterbox myself as I always work in 16:9, letterboxing to 4:3 throws away a lot of resolution. |
if you're working in HDV timeline, and want to capture HDV footage off a deck, what setting should the conversion options be at? Leterbox or crop, i don't recollect there being a "off" mode for conversion... Thanks
Bob the one problem I might see is if I shoot in HDV which is most of the time I want to down convert to SD in the 25U. If it does not give me letter box when I down convert to SD what option will I have for 16:9. I have never used squeeze. Is this the option?
Sorry if I am missing the point I just want to make sure the deck will do the down convert job and still handle the HDV load prior to spending the money. Thanks for your help. |
What is called "Squeeze" is what you want. That gives you real anamorphic 16:9 DV, it's the same aspect ratio as HDV. Don't know why Sony called it Squeeze, maybe Anamorphic was too long to fit on the menu?
Letterbox is giving you a 16:9 sized image fitted inside the 4:3 frame, you get black bars top and bottom. If you manage to convert that back to real 16:9 then you've lost 30% vertical resolution in the process. |
Thanks Bob that makes sense to me.
This is good info since I have been using Letterbox downconverting from the camera. I did not know I was cutting off so much information. Now if I use squeeze and I go to a 4:3 tv with the DVD that was made from a timeline where the video came in Squeezed what will happen? |
Thanks everyone for your help I purchased the 25U deck today from B&H. Also purchased yesterday and am playing with now DvFilm maker, wow great results.
| All times are GMT -6. The time now is 10:51 PM. |
