-   Monopods (incl. FlowPod) (https://www.dvinfo.net/forum/monopods-incl-flowpod/)
-   -   Monopod for EX3 (https://www.dvinfo.net/forum/monopods-incl-flowpod/130351-monopod-ex3.html)
Matt Sturns September 11th, 2008 11:21 AM
Monopod for EX3
Any suggestions for a monopod for the EX3? I was looking at the Bogen carbon fiber (max load 11 lbs.) but it would be great to have some sort of head on it. I cannot seem to find an adequate head. I shoot the EX3 with the big 60 battery and shotgun, and hopefully a the Sony hard drive w/ battery so I guess I am looking at a payload around 12 lbs?
Any suggestions? Thanks :)
Matty S
Jamie Peters September 11th, 2008 01:57 PM
I am not happy with the single fixing screw for this large camera on a tripod so my advice re a monopod would be 'don't even think about' with a single 1/4 inch screw.
I have seen people using the HDV Z1 on a monopod but they are much smaller and lighter.
Steve Shovlar September 11th, 2008 02:09 PM
Get the manfrotto 561B. Its excellent.
YouTube - Bogen Manfrotto 561B Monopod
Leonard Levy September 11th, 2008 02:31 PM
ditto, on the bogen above and add a simple cheap bogen tilt head - don't remember the number - your choice with or without a quick release.
You can also get 2 cheap Bogen or Giotto sliding base plates and put one on your tripod and one on the monopod then you can go quickly between TRIPOD AND MONOPOD.
Get a fanny pack for the monopod also.
Matt Sturns September 11th, 2008 02:51 PM
thanks guys for the info. One question, on the site it says the load capacity is 8.8 lbs. With a battery, hard drive, mic, etc I am guessing the load capacity is too much?
Has anyone tried the Manfrotto 562B? It says it has a load capacity of 17.6 lbs which should be more than adequate. It looks as though the head is much different, though. Any advice? thanks for the current info, much appreciated:)
Matty S
Leonard Levy September 11th, 2008 03:29 PM
get both and send one back
John Hedgecoe September 11th, 2008 04:13 PM
Try this, and put the head of your choice on it...
Bogen / Manfrotto | 685B NeoTec Monopod Deluxe | 685B | B&H
33 lb load capacity, and the neotek design makes adjustments sooooooo easy.
Andrew Hollister September 11th, 2008 05:13 PM
What about that new Sachtler Soom system? You can buy the individual bits... and max payload on the extender pole / monopod is 19.8 pounds
sachtler: Tripods
Sachtler | S2005-0001 Soom Tube | S2005-0001 | B&H Photo Video $489
Maybe expensive but it could be the start to a nice bit of kit
John Peterson September 12th, 2008 10:16 AM
That's probably a much better option than the 561B. I have a 561B and I hate it. Using a VX2000 it wobbles all over the place resulting in camera shake with little provocation. I consider it a total waste of money and I only bought it because of the generally positive writeups. Seems best suited for a compact DV pocket camera. A cheap thin tripod would work better.
John
Matt Sturns September 12th, 2008 03:01 PM
thanks for the info guys...got some research 2 do...
Leonard Levy September 12th, 2008 04:24 PM
" Using a VX2000 it wobbles all over the place resulting in camera shake with little provocation."
How are you using it? Do you have a head on it? I use it for handheld work braced in fanny pack. No opportunity for wiggle, Can't imagine it.
Maybe you are standing up and trying to hold steady shots from standing height. I wouldn't use it that way I don't think.
I wouldn't want anything heavier.
Lenny
Roger Shealy September 12th, 2008 05:11 PM
Bogen 561b is good. A little heavy, but a good system if you need to move, pan, and tilt.
John Peterson September 12th, 2008 07:13 PM
Lenny
When I use it that way (like a steady stick along with a fanny pack) it works fine, but so do most monopods. But, yes it is in fact designed to hold steady shots from standing height and in that respect it fails miserably. Yes. it does in fact have a head on it.
But in fairness, I checked my monopod and it is in fact the 560B and not the 561B. They look the same. Not sure if there is a difference:
Amazon.com: Manfrotto 560B Fluid Video Monopod with 234RC Head (Black): Camera & Photo
John
Dan Chung September 12th, 2008 10:01 PM
I would go for the Velbon Neo-pod 8, Velbon Tripods which I think can also be bought as the Miller monopod.
Far, far better than the manfrotto IMHO, is actually pretty much a single leg of a Miller DS20 tripod. Light and incredibly sturdy but not as expensive as a Gitzo of similar build. I can use it to support my EX1 or DSR500 with no problems.
Dan
Leonard Levy September 12th, 2008 10:01 PM
I can see it wouldn't be that steady free standing , but are any of them. I usually brace it against my body to triangulate for standing shots & that works fine. Never tried anything sturdier in a monopod. I don't want anything heavier.
