error from ProTitler 1 upgrade (to 2)
I upgrade from ProTitler 1 to 2, had some challenges with it and NewBlue (I believe it was) suggested I uninstall 1 and 2 and just install 2. I did that. My system has been much more stable since.
I opened an old project that I used ProTitler 1 with and get the error message the "plug in specified are not installed". What do I need to do to read these cg that where created in ProTitler1? I have quite a few of them. Thanks for your assistance, James |
Re: error from ProTitler 1 upgrade (to 2)
James
From my experience they are 2 completely different programs. To use your titles created in ProTitler 1, that program needs to be installed. David |
James, you would need to reinstall Titler Pro 1, open that project, and then open that title and do a "File - Save As"
You can then uninstall Titler Pro 1, open the project again, change that title to a Titler Pro 2 title, and then do a File - Open and open the file saved from Titler Pro 1. The "changed from Titler Pro 1 to Titler Pro 2" instructions are in the help file. As Titler Pro 1 and Titler Pro 2 are two completely separate products, TP2 will not automatically replace TP1 events. |
David and Edward,
I re-installed ProTitler 1 and it is working. I needed to do a slight edit and re-render a project I've been working on. Edward I will look into doing save as for all those titles. Thanks!!! James |
| All times are GMT -6. The time now is 06:33 AM. |
