-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Editing PC won't boot (https://www.dvinfo.net/forum/non-linear-editing-pc/139822-editing-pc-wont-boot.html)
Ron Cooper December 17th, 2008 06:30 AM
After running the defrag on "C" drive, it hung at 47% & I had to manually switch off.
Now after re-booting, the PC goes round in a loop - it gets to a screen
for you to select options such as - start windows normally, - safe mode etc. , yet when you select any, it just re-boots back to the same screen.
I tried booting via the windows disc but in the end it always points me to a screen where you have to re-install windows & lose all previous data, which is something I am loathe to do as I have heaps of programs & apps. on it. - Any suggestions ?
Details, - Win XP Pro, P4 core 2, 2g. RAM, sep. drives for C - (programs), & editing.
RonC.
Tripp Woelfel December 17th, 2008 07:26 AM
The failed defrag probably trashed a critical OS file. You'll probably have to re-install the operating system, unless someone knows a short cut. I've only done clean OS installs so I don't know if the Windows installer offers a "repair" option.
For future reference, it's a very good idea to run a full SCNDSK with full surface scan and repair options selected periodically to check all the sectors on disk. That will verify that all the physical regions of the disk in use are in good working order.
One thing that might have happened to you is that defrag tried to write to a "soft" sector and couldn't get the write to complete. From there it lost its mind and crashed/looped. There could also be a more mundane cause such as a power spike or micro-singularity.
Jeff Harper December 17th, 2008 07:49 AM
Tripp may be correct about the failed defrag causing the problem.
If you haven't already, look in your bios make sure the hard drive still appears...than get your hands on or make a floppy with check disc on it and run it and see what happens.
Check disc can sometimes fix or recover messed up sectors.
K.C. Luke December 17th, 2008 08:25 AM
Code:
Are you running a old system? P4 core 2???
What type of CPU you are running? Intel or AMD?
I think your CPU may over heat!!!
Ervin Farkas December 17th, 2008 11:32 AM
I had the exact same symptom a couple of weeks ago, except I was not defragging, I was in the middle of formatting an external hard drive. Turned out, the hard drive went south.
If you have additional drives in the computer, disconnect them, that might be the cause.
Ron Cooper December 17th, 2008 03:56 PM
Thanks very much for all for your help. I will investigate further as suggested but to answer a few details here they are :
The processor is an Intel Core 2, 6400 @ 2.13GHz. Speed 2133Mhz, Count 2. All HD's are recognised OK in the BIOS. - AMIBIOS v 0901 B/D 12/19/07.
I would be surprised if it is a heating problem as all fans are OK & it's reasonably clean inside. Also, it has never shown any instability problems or overheat warnings and I was editing on it without any (PC) problems before I decided to do a defrag, so I too, think that the defrag caused the problem. BUT, just before this, I did try to do a scan - (C drive/properties/tools/scan ) and it asked me to check two boxes to authorise it to do a scan after the next re-boot. This I did, but when I re-booted it just started normally, - no scan. I then repeated this & duly re-booted again, but still no scan, so then I decided to do the de-frag.
The main C drive is good Samsung 250 g which is only about a third full. The defrag was going for about 1hr. - ( went & had tea) and when I returned it was at 47% which I then left it at for about another 20 mins. before I considered it to have hung.
This machine is less than 18 months old and is only connected to the NET for updates etc. - I keep the plug pulled most of the time and it is not used for surfing or email, so bugs are unlikely and naturally I do have an A/Virus program as well.
I will try and make a check disc from the BIOS but I am not quite sure how to do this as I thought these could only be made via windows XP which of course is now catch 22.
RonC.
Jeff Harper December 17th, 2008 04:24 PM
Good luck. You could make the disc on someone else's pc if possible.
or if you have an old hard laying around install windows on it, make your disc then reinsert your original drive.
Ron Cooper December 17th, 2008 04:56 PM
That's no problem Jeff, - I have a working PC with XP Pro on it, but I thought all these do is allow to do a complete re-install & lose all your programs.
RonC.
Vito DeFilippo December 17th, 2008 08:40 PM
You can let the Windows XP install try to repair your installation. At one point, it asks if you want to repair using the console. That's not what you want. Continue on, and choose install. It will scan your disks and find the already installed XP, and ask you if you want to repair it.
If you choose to do so, you lose no documents, and your programs should still work. You just lose all Windows updates and have to redo them.
You can find info on this option easily. Check here for example for details:
How to Perform a Windows XP Repair Install
I would highly advise backing up the drive first, though. Always a good idea before trying something like this. For what it's worth, I've done it a few times with no problems.
Jeff Harper December 18th, 2008 05:43 AM
You need to run check disc....that program needs to be on a floppy. You need to create the program on a floppy.
This program (Named Check Disc) needs to be run (in DOS) to check for bad sectors on your hard drive.
If you don't have any clue as to what I'm talking about, then you should or could take your PC to a repair center to let them do the same thing, or reinstall windows.
Good luck!
Ron Cooper December 18th, 2008 04:09 PM
Thanks Jeff & Vito. I have already tried to repair as you exlplained Vito, - did that first but I realise now that the reason that the windows disc ends up not giving me a repair option at the end of the repair console, is that there is probably not enough usable data left. There is one section where you have to check the agreement & then it gives you the repair option, but in my case it does not, it just asks if you want to install windows (& hence lose all your apps.), or exit.
Now regarding check disc I have used this before within Windows but not from a separate floppy. So I went into my other computer to see if I could put in on a floppy, but it could not locate the file. --?
I am wondering now if I re-connect the drive to another bus and fit another drive - I have a few around, just to enable me to install XP on that one and then (hopefully) transfer all the programs etc, back to the new one and carry on.
I'd hate to have to rely on this for a living as I seem to have a major crash about once a year ! Perhaps I should buy a Mac !
RonC.
Tripp Woelfel December 18th, 2008 07:06 PM
I've not tried it but you should be able to run it from a CD-ROM. I'm just not sure what else you'll need for a basic operating system.
You might try the support pages at the Microsoft Web site. I know it's a bit like going into the abyss, but you might get lucky and find what you need.
Jeff Harper December 18th, 2008 07:29 PM
Go here and download the program that most resembles your hard drive for Western Digital Drives
WD Support > Downloads > SATA Hard Drives
Or if you have a Seagate drive go here:
Seagate Technology - SeaTools
and download SeaTools for DOS.
Hopefully your hard drive is not bad and can be fixed with one of these tools.
I have read that the Western Digital software works with any drive...Seagate only is meant for Seagate drives, but their Seatools still has some functionality for other brands of drives.
George Bean December 18th, 2008 09:08 PM
if you have access to another computer:
remove the drive that will not boot and temporarily install it in your second computer.
if it is an ide drive verify you have the correct settings for the jumpers designating master or slave drive on the ide channel, if it is a sata drive there are no jumpers.
boot into windows.
view the drive letter assignments in windows explorer, your temporary drive from your editing computer will be assigned a drive letter. Once you verify the assigned drive letter navigate to your start menu and select the run dialog box.
in the run box type
chkdsk d: /f
replace the letter d with the correct drive letter windows assigned to the drive.
the /f is the fix command
this should take only a few minutes to check and repair. when it is complete shut down the
computer, return the drive to the original computer and all should work.
when windows hangs and or refuses to shut down press and hold the power button of your computer for four seconds. this forces windows to shut down without corrupting the files.
Vito DeFilippo December 18th, 2008 11:33 PM
You mean it's not detecting the existing partition at all? It just wants to reformat your drive and install anew?
If yes, sounds like you hosed your parition table, or the mbr on the disc. There are software available to fix this. Patition Doctor is one. I had a similar problem not too long ago after a power surge. Partition Doctor detected the damaged parition and fixed it for me. I was then able to boot into Windows normally.
GetDataBack is another great program that will (slowly) scan the drive and allow you to copy your data to another drive.
Jeff Harper December 18th, 2008 11:33 PM
Nice idea George, but how will a drive that will not boot on one PC boot on another? It would be far simpler to use a disc utility on his problem PC than to remove the drive and put it into another machine.
While it wouldn't hurt to check jumpers, if it was working properly until he defragged, that means it was set properly to begin with. If his jumpers were incorrect it wouldn't have been working to begin with. It's like the idea someone had that his processor was overheating. Processors don't go along fine and randomly start overheating, expecially on something simple like a defrag...
The chances his problem drive, under any circumstances, booting up on a different box are pretty slim...at best he would get safe mode even if the boxes are similar. The graphics drivers and chipsets would be likely be completely different and it wouldn't function.
I suspect he may have a bad hard drive anyway. I hope I'm wrong, but it has the symptoms. It could go either way. Hopefully he'll get it fixed and let us know what happened.
Vito DeFilippo December 18th, 2008 11:42 PM
I think he means install the drive as a second (slave) drive and use the other computer's operating system to boot into Windows. Then he could use checkdisk.
Ron Cooper December 19th, 2008 07:45 AM
Most humbly to Mr. George Bean !
Or to put it in Aussie parlance, - Bloody Brilliant Mate ! IT WORKED !!
Now the details -(only if your interested), I removed the offending C drive from PC-1 & plugged it into the other (working PC-2) as you suggested, and I put it on a secondary SATA bus. in case it would confuse it with the C drive which is an IDE.
At switch-on IT AUTOMATICALLY DETECTED IT AS DRIVE F & STARTED A CHKDSK on the offending drive which took about 5 - 10 mins. - Thousands of entries corrected. - it ticked over like a high speed clock , but then on the last part (sect 5), it stopped, as it just said 0% completed. I left it for about ten minutes & then cancelled. Then it (PC-2) booted up on its normal C drive.
I realised that 3 days ago, I had set PC-1 to do a scan on the offending drive on re-boot, before it failed , BUT, on re-boot, it did NOT do a scan, so that was when I decided to do a de-frag and the problems started. So I guess that is why it scanned automatically when fitted to PC-2.
The curious thing is then why did it not do this in its original PC (same drive, same OS), instead of going into the loop at switch-on as described in my first post.
Of course I then removed the drive & replaced it back into PC-1 and just after switch-on, it stopped again at the same option screen - normal, safe-mode etc., but this time when I selected normal it did a normal boot-up.
I then ran a registry program - RegCure which found 460 problems and said it fixed them all ! I then ran it again & it said the same but with 39 problems. After doing this another 2 times the problems became zero.
I then selected it to do another scan at boot-up, and then I re-booted it. However, it did a scan but again when it got to part 5 it again showed 0% progress for about 15 minutes so I cancelled & it booted up normally, and so far seems to be fine.
I can only say thank you all very much for all you help in this saga which thankfully has a good ending.
RonC.
George Bean December 19th, 2008 10:39 AM
[QUOTE=Ron Cooper;980802]
windows has certain files it needs to access in a specific order to boot. when a pc is shut down unexpectedly these files are still on the hard drive but windows becomes confused as it does not read these files in the order it expects. this a a very simplifed explanation of why you get caught in the continual reboot loop.
windows starts, looks for a file, does not find file, shuts down starts again, looks for file, does not find file.... etc.
the quickest way to repari is run chkdsk with the /f command. the easiest way is to install the corrupted drive in a spare computer. the chkdsk will reorder the files the os needs to properly boot.
this most common cause is windows being shut down unexpectedly. always selct shutdown form the start menu or hold the power button in for four seconds until your pc powers down to avoid confusing windows.
Jeff Harper December 19th, 2008 11:36 AM
Way to go George, well done.
George Bean December 19th, 2008 02:49 PM
at some point either windows or your hard drive will fail. it is best to have a backup so there is no lost data and no downtime.
there are several options and reveiw and choose what is best for your situation, i use
acronis true image. i am not affialiated in any way shape or form with acronis, but the
true image program has saved my a$$ more than once.
two important features in an imaging program are being able to run the softwre from within windows and also the use of external usb and firewire drives.
here is the process:
from within windows start the true image program
select the drive you want to image
select a destination and name for the image
choose full backup and a name for the image
store your image on a portable drive in a safe environement
the program has a point and click process for making a bootable disk for restoring images
to restore an image when windows or your drive fails:
verify your cd/dvdrom is the first boot device
place your bootable cd into the drive
the true image program will run form the cd and prompt you step by step
it will ask what drive you want to restore and where the image file is located
if windows becomes corrupted, a hard drive fails or your pc gets a virus it typically takes less than a half hour to restore an image.
Ron Cooper December 19th, 2008 03:47 PM
Thanks again George, very helpful advice.
I forgot to mention though, in case you got the wrong impression, that I did always shut the thing down by holding the button for four seconds, but it still crashed. I'm puzzled as to why it did not go into the scan program when I originally scheduled it on the next boot-up. - ( With my old {A B I W }*, Win 98 machine at work you simply click on "Scan for errors" & choose quick or thorough, & away she goes. - None of this palava about access rights and scheduling on the next boot-up !)
I did notice though, that when it started the de-frag that the drive was very fragmented according to the red bars in the window, indicating to me that I should have defragged it more often.
RonC.
(Sorry for the grammar error in last post - it should have been you're - it was 1 AM !)
* Ancient-But-It-Works !
