-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Old computer upgrade.. (https://www.dvinfo.net/forum/non-linear-editing-pc/145795-old-computer-upgrade.html)
Terry Lee March 14th, 2009 10:15 AM
I am wanting to upgrade my old Dell 2350 model computer to something that has more disc space, RAM and a larger monitor. However, I am concerned that the motherboard won't accept my choice of RAM which is Corsair XMS3 2048MB Dual Channel PC10600 DDR3 1333MHz Memory (2 x 1024MB).
Currently I am running 512 (haha). I've had this computer for over 6 years and would simply like to make it preform alittle better. It is not a system I plan to edit video from, however I do plan on putting my finished projects on this computer for storage and viewing purposes. Therefore I have chosen a Seagate Barracuda 1.5TB Hard Drive ST31500341AS - 7200RPM, 32MB Cache, SATA-3G and a Samsung 22" Monitor.
The total is $350. My strategy is to be able to use these same parts for further upgrades of a mobo, processor in a larger tower with a bigger power supply in the future.
So my question is, Will my motherboard be able to handle 2048MB 1333MHz of RAM?
Terry.
Pete Bauer March 14th, 2009 06:24 PM
No, DDR3 RAM and a six year old computer aren't compatible. If your only use for the computer is to store video files, I'd say just get a couple large capacity external drives with the $350. With two drives, you'll have redundancy in case one fails (keep them both up to date -- "mirrored" -- and one should stay off-site) and then sell or donate the old computer.
If you do have other purposes for the old computer for which it isn't quite doing the job, I'd still say most likely you're better not upgrading but just getting a new system. I'd wonder if the ol' system would even playback HD video smoothly?
Tripp Woelfel March 14th, 2009 07:57 PM
Good grief! In today's world that computer is the equivalent of a wind up Victrola that plays 78s. (grin)
A quad core and max RAM is really the minimum for editing native HDV. Anything less will have you looking for a ball peen hammer to use on something.
Terry Lee March 15th, 2009 06:41 PM
HAHA! Well the thing is, this old computer works better than most computers I work on at my university so I never saw the need to get a new one. However recently I think its starting to get worn out. Its becoming slow to respond. The only thing I could do is just up the RAM.
An entirely new system is definately in the future but probably not for editing. I tried to build an edit system a couple times and it reached close to the $1500+ mark each time. Around $500 is what I'm willing to pay for an upgrade. Don't laugh but right now, I'm using a 15" monitor... I'm seriously thinking about buying an HD TV to slap on the wall so I can just hook my computer and cable box to it.
Lee Matheson March 17th, 2009 09:36 AM
Consider a graphic card upgrade?
You did not specify what graphics card you have in your old PC.
An interesting tidbit that I found, when researching Non Linear Video Editors, was I learned that there may be advantages possible by offloading the decoding and post processing to the GPU (from the CPU). Specifically, the inexpensive nVidia 8400 GS cards (such as the Asus EN8400ES Silent/HTP/512M card with the G98 GPU) have better support for VC-1 and MPEG2 than the more expensive nVidia 9800GTX+ 512MB cards (which only have the G92/94 GPU). The nVidia 8400 GS cards requires a PCIe (PCI-enhanced) slot in one's older PC. Both cards (that I mentioned) have GPU's which provide the same support for H.264.
The nVidia 8400GS cards are relatively inexpensive, and if one gets one with Pure Video support, and then also uses NLE software that specifically takes advantage of Pure Video (and not all software does), then suddenly one's old PC becomes a viable platform for AVCHD Video Editing, where only significantly more powerful (and newer) PCs could do the job before.
Note that one does have to identify the right software package to use with the card/PC combination.
I'm a Linux user so I can't provide Windows recommendations, but since there is a Linux program with capabilities in this area, I suspect there must also be MS-Windows programs.
While I was trying to wrap my mind around why a less expensive card could be more capable than a much more expensive card from the same manufacturer, I note this is only for Pure Video HD support and that the newer nVidia cards (such as the 9800 GTX+ I mentioned above) are significantly superior in all other respects (especially superior wrt games). I think the faster clock speed of the 9800 GTX+ also means H.264 decoding would be quicker than the 8400GS. Its only in VT-1 (wmv codecs) and MPEG2 that the nVidia 8400 GS GPU has 3rd generation capaabilities that the 9800 GTX+ does not. I note this thread from a nVidia support site FAQ when trying to explain this difference: PureVideo HD FAQ
Q. Do the GeForce 8800 series GPUs include the same video processing capabilities as the new GeForce 8400, GeForce 8500 and GeForce 8600 GPUs?
No. The GeForce 8800 uses the previous generation of PureVideo HD. This is because the GeForce 8800 is usually paired with more powerful dual-core CPUs and our goal is to achieve balanced use of all the processing power in your machine. With the GeForce 8800, it makes sense to let these powerful CPU cores handle functions they do well. But with the lower-end GPUs, which are usually paired with less-powerful, single-core CPUs, it is better for the GPU to take on the entire video decoding and processing task and the new PureVideo HD engine has been enhanced with these chips in mind.
... I also wonder a bit as to how much of that is marketing, and how much technical fact? I have read that the GeForce 9600/9800 series are not changed much from the 8600/8800 series
Anyway ... I offer this suggestion to look at graphic cards as food for thought.
Ervin Farkas March 17th, 2009 12:35 PM
Leave it alone
You might be better off leaving it alone as it is... OK, maybe add another 512MB of RAM ($20), that would speed up the system a little. Other than that it's just not worth investing in that old clunker.
What might bring you significant speed increase is wiping the hard clean and installing the OS anew. It's amazing how much junk computers accumulate over the years, and there is no software that would clean it out properly.
Save the change for a new one.
Jeff Harper March 17th, 2009 12:58 PM
I agree, reformat your hard drive, but I wouldn't put a single penny into your PC.
Terry Lee March 17th, 2009 06:17 PM
Hmm. So bring it up to 1GB?
I'll give it a shot. Can't hurt.
What do you think about hard drive space though? The hard drive in this thing is a whopping 30G..... and probably has a buffer memory of 2MB.
To be honest I think I have DDR2 in it now.. i'll have to check.
David Chilson March 17th, 2009 07:08 PM
Terry,
Here is a link to the Corsair website that has a few specs on the Dell 2350 and their recommended memory. It also lists the memory type that came in that computer.
Dell Dimension 2350 Memory Upgrades - Guaranteed Compatible Memory for your Dell Dimension 2350 from Corsair
But, like those who posted ahead of me I wouldn't do anything more hardware wise than update the ram and if I were crazy enough to do that I would buy a set. (2 X 512) Who knows if what you purchased would match what you had in there.
Like the others before me stated, reformatting your hard drive and reinstalling windows 98 :) or whatever operating system that came on there would be the best bang for your buck.
If you spend any more money on that old thing we may have to have you committed! Anything that you could add to that machine you sure as heck wouldn't want on a new one.
Good Luck
Terry Lee March 17th, 2009 09:24 PM
HAHA! Its not that old c'mon! I actually have Windows XP on this thing. I've done some upgrades in the past. I had it reformated maybe 6 months ago so I'm good in that perspective.
I'm in the process of building a new computer, so I won't be in the stone age much longer!
Ervin Farkas March 18th, 2009 06:38 AM
That's fine for the OS and whatever other software you want on it (keep it at a minimum). Don't put anything else on that drive!
Standard definition video will play just fine from an external USB drive, if you want HD, get a $10 eSata card and an eSata external drive... but that will bring your oldie to the brinks... better keep it SD.
Terry Lee March 18th, 2009 10:52 PM
The hard drive for my new system will certainly atleast be Firewire-400. USB I hear is slow as Christmas. eSata would be my next choice but they seam to be on the more expensive side. BTW, Whats up with SolidState? I have no clue what that is but the hard drives are like 250GB for nearly $700..
For this old system, I just want to make it work a bit better so I can give it to someone who doesn't have a computer.
Thanks for the help.
Terry Lee
Lee Matheson March 20th, 2009 11:54 AM
More thoughts on 8400GS
I looked a bit more into the nVidia 8400GS cards, and in addition to there being many of these cards for the PCI-e bus, there are also 8400GS cards provided by 4 different suppliers for the much older PCI bus (from PNY, BFG, eVGA, and Sparkle) where with the right nVidia driver, these cards provide Pure Video 2nd generation support (ie vdpau support for Linux). However as near as I can glean, those are only for the 64-bit PCI and not for the 32-bit PCI (my old computers are only 32-bit and hence this is not a solution for my old PCs). There are no 8400GS cards for the AGP slot as far as I know. There are some relative (to nVidia) advanced ATI cards for the AGP slot, but in Linux terms, I don't think the ATI cards have as much support for off loading the video decoding to the GPU.
In fact, I'm likely going to purchase a new PC (Intel core i7, possibly with a nVidia 9800 GFX+++ graphics card). As has been noted by others, ... there comes a point where if one's PC is too old, it does not make much sense in continuing to upgrade the PC.
Robert M Wright March 23rd, 2009 09:11 AM
512 megabytes of RAM is pretty minimal for running XP (not enough headroom for apps, without a whale of a lot of swap file usage - which is S-L-O-W.). Going to 1 gigabyte of RAM will almost assuredly boost performance significantly.
Also, from what I've gathered, the Seagate 1.5 terabyte drives are problematic (just look at feedback on Newegg). I'd stick with the 1 terabyte drives for now.
Lee Matheson March 23rd, 2009 02:14 PM
Correction re: PCI 8400GS card
Turns out I was wrong here. There are nVidia 8400GS cards for the 32-bit PCI on old PCs. They are not too expensive (albeit they cost more than the 8400GS for the PCI-e bus). I found 4 different GS8400 Cards, all of which have a 32-bit PCI card:I also found very detailed pix for the BFG, PNY, and eVGA, confirming that they all seem to be of the "universal 3.5 and 5.5 volt 32-bit PCI card" type.
I then compared those pix to these articles explaining a bit about PCI cards, with great pix/sketches:Again, the 8400 GS cards (depicted on the various web sites) shape matches that of the "universal 3.5 and 5.5 volt 32-bit PCI card" type depicted in the tutorials on PCI cards.
Since I found a web site where I could order the BFG nVidia 8400GS, I sent BFG support an email asking their assessment if the card would function in an old PC of mine (listing my motherboard, with pix) , and their prompt reply/assessment was there would be no problem. I also checked the power requirements to ensure the power supply in my old PC could handle the power requirements of the video card (card requires 300 watts).
In the end, I decided to go ahead, and I ordered one BFG nVidia 8400GS PCI graphic card. Its inexpensive, and I have 3 old PCs in which I can test it on, to see what its GPU does for offloading the H.264 encoding from AVCHD to the graphic card, and smoothly ( ? ) displaying it on my monitor. If it works on the oldest PC, I'll purchase more of the cards for the other old PCs in our flat.
Note that does not solve encoding issues. But I'm happy with Linux encoding of AVCHD, and thus far I've been able to encode (albeit slowly) samples of the highest resolution/encoding of the AVCHD formats from the camcorders that interest me.
A common thought I had (that has been expressed in countless threads) is that bandwidth is a MAJOR limitation when referring to the PCI bus in an old PC. ... But, there is also a differing school of thought that views the bandwidth limitation being less than the CPU limitation in an old PC, and that the PCI bus is large enough to offload the encoded H.264 to the GPU for decoding, where upon it can be displayed smoothly if the GPU has sufficient on-card memory.
So I anticipate, if nothing else, I'll have fun playing with that, until I finally purchase my new PC (Intel i7 Core based) in the next month or two.
As an aside, I note one Ubuntu user of a PC older than mine (600mHz PIII) , claim the inexpensive 8400 GS works well in playing High Definition Video: XBMC Community Forum - View Single Post - XBMC for Linux VDPAU support (ongoing development in an separate SVN branch) ... note this is likely playing back the video with software specifically designed to take advantage of VDPAU (the Linux nVidia Pure Video equivalent) and not just any piece of software.
Terry Lee March 24th, 2009 07:07 AM
Currently in this system I have an XFX GeForce 6600.
Lee Matheson March 24th, 2009 12:34 PM
AGP card?
I can't tell if there is Pure Video support for that card, based on the nVidia site:
NVIDIA PureVideo
where they give this:
http://www.nvidia.com/docs/CP/11036/...Comparison.pdf
Is this an AGP card? The Pure Video for the AGP cards does appear to be more limited than for PCI or for PCI-e.
Lee Matheson April 2nd, 2009 12:04 AM
vdpau decoding support for playback in openSUSE mplayer
I'm still waiting for the 8400GS nVidia card to arrive. But in the mean time, the good news is the Packman packagers for openSUSE Linux 3rd party applications, now have available a packaged version of mplayer ( MPlayer-1.0rc2_r29116-2.pm.2r ) that will use a vdpau capable graphic card for decoding ( only if such a card is installed on one's PC). This also requires the nVidia proprietary graphic driver to be is in use on one's openSUSE Linux install (and not the vesa nor openGL graphic driver).
I was thinking I would have to custom compile mplayer when my graphic card arrived, but this appears no longer to be the case.
Until my graphic card arrives, I can't comment on the stability of this Packman packaged mplayer version, nor if there are any tearing or other issues. But its a positive step forward to have a packaged version of mplayer available for quick installation on openSUSE Linux. I'm hoping this will significantly improve the playback of AVCHD videos on my older PC.
Lee Matheson April 5th, 2009 02:37 AM
Some early test results of old computer upgrade
As noted, I ordered the BFG 8400GS PCI card last week. Card specs here: BFG Tech - BFG NVIDIA GeForce 8400 GS 512MB PCI . The card just arrived by mail yesterday and I could not resist playing with this card in my oldest PC, so I gave that priority and tried it out. For the testing on my openSUSE-11.1 PCs, all running KDE-3.5.10, I did not custom compile MPlayer, but rather I used an rpm packaged by the Packman packagers, who are a group of packagers who package rpms for openSUSE. Packman Packager for openSUSE - MPlayer
Hence I tested the latest packged packman MPlayer-1.0rc2_r29116-2.pm2 on a 9 year old PC (athlon-1100 (1GB RAM) with the new nVidia 8400GS graphic card noted above) running openSUSE-11.1 with KDE-3.5.10. This old PC has a 1x/2x/4x AGP slot (no PCI-e bus). I removed the PC's existing nVidia MX400 (64MB) AGP graphic card (which had been using the openGL driver for nvidia) and replaced it with the nVidia 8400GS PCI card and then I installed the nvidia proprietary 180.44 graphic driver.
With the nVidia 8400GS, and MPlayer, and the Nvidia proprietary 180.44 graphic driver (using VDPAU (the Linux Pure Video equivalent)) this 9-year-old old PC was able to smoothly play back 2 of the H.264 trailer videos from this web site that I tried: H.264 Demo Clips « H264info.com
The two successful videos that were played back (on this old PC with the new card and VDPAU) were Fantastic Four: Rise of the Silver Surfer - 720p Trailer, and Serenity - 720p “On HD DVD” Trailer. They BOTH have LOTS and LOTS of movement. The playback had problems playing back a 3rd video trailer: I Am Legend - 1080p Trailer (more details on that problem later - I obtained the typical green MPlayer VDPAU screen after 10 seconds or so of playback).
For example, in the cases that worked, with MPlayer, playing Serenity trailer on the 9-year old athlon-1100 with the 8400GS PCI card and VDPAU, the video played smoothly, and the athlon-1100 CPU load of MPlayer was only 4% to 5% load. Trying to play the video without VDPAU on that old PC results in the video freezing. This freezing without VDPAU was also true on that old PC with the MX400 AGP card (that was removed). The Serenity trailer is H.264 encoded, 1280x720, at 4.8MB/sec with LOTS and LOTS of movement.
Playing the same Serenity trailer video on a 5-year old athlon-2800 (2GB) with nVidia FX5200 AGP (128MB RAM) and openSUSE-11.1/KDE-3.5.10 with MPlayer (without VDPAU) resulted in 75% cpu being used by mplayer and 18% Xorg and the video played poorly, jerking and with a massive audio/video desynch (ie it was NOT watchable on the athlon-2800 with the FX5200 AGP graphic card).
Playing the same Serenity video on a 6-month old (Dell Studio 15 laptop) with Intel Core2 Duo P8400 with Radeon HD3450 (openSUSE-11.1/KDE-3.5.10) with MPlayer resulted in 70% cpu from MPlayer, but that very new laptop PC gave a smooth video playback.
The downside to this new hardware was the nVida 8400GS 180.44 proprietary graphic driver was very unstable on KDE-3.5.10 on the athlon-1100 doing regular (non-multimedia related) functions. I was not able to get more than a couple of hours operation with out the graphics failing and a reboot being required. On a KDE4 install, the proprietary nVidia driver was mostly non-functional with only minute or two of operation before a freeze on KDE4. Hence the PC is debateably not useful with this lack of stability, and hopefully nVidia will continue to improve the stability of their driver with and without VDPAU.
When using the VESA desktop graphic driver driver with the nVidia 8400 GS PCI card on this old athlon-1100 PC (where there is no VDPAU support with VESA driver), the PC is stable, but very slow (slower than the MX400 AGP card with the openGL driver).
Its possible this new BFG 8400GS PCI graphic card is not completely compatible with the old PCI bus on this athlon-1100, and in a week or two I hope to try it out on the slightly newer (5 year old) athlon-2800 PC mentioned above.
On the web site where I noted I obtained the test videos, the I Am Legend - 1080p Trailer would run on MPlayer for about 10 seconds and then fail with a solid green screen, with a series of errors, such as:
Code:
[vdpau] failed VDPAU decoder rendering: An invalid handle value was provided
[vdapu] Error when calling vdp_video_mixer_render : An invalid handle value was provided
[vdapu] Error when calling vdp_device_destroy : An invalid handle value was provided
[vdapu] Error when calling vdp_presentation_queue_display : An invalid handle value was provided
[vdapu] Error when calling vdp_presentation_queue_block_until_surface_idle : An invalid handle value was provided
But given NONE of these videos could be played BEFORE, the new 8400GS card using MPlayer with vdpau was installed is a big improvement. But clearly its also experimental (due to the lack of stability).
As a further note, I also saw the same green screen failures (anywhere from seconds to minutes into playing a video) with MPlayer and VDPAU when playing back a standard DVD compliant MPEG2 file (720x480, NTSC (29.97 fps), 2.845Mb/sec). Those failures are not too serious from a practical perspective, as those videos can be played without VDPAU on the same graphic PCI card and same PC (albeit without VDPAU there is 75% CPU load as opposed to 5% CPU load with VDPAU). But MPEG2 DVD format is very common, so clearly there are problems here, either with the nVidia 180.44 driver or with the MPlayer VDPAU implementation.
In summary, both the nVidia 180.44 graphic driver, and the VDPAU driver in ffmpeg/mplayer are not stable yet (on this 9-year old PC) with the BFG 8400GS (512MB) PCI graphic card, and the driver/software is STILL experimental as is noted. However it has TREMENDOUS potential for breathing new life into a very old PC.
I'll likely be trying this BFG nVidia 8400GS PCI card on a 5-year old Athlon-2800 sometime in the next few weeks.
Fred Phillips April 25th, 2009 01:03 PM
Minimum editing computer specs editing on Sony Vegas
First of all I am a real newbie to consumer camcorder video. I am a stills photographer in the fashion/model industry. Recently I acquired a Sony SR 11 camcorder and took it on a trip to Europe and Thailand. I now have lots of clips shot in HD mode (AVCHD) and I have reached the stage where I want to do some simple editing. I want to install Sony Vegas Platinum editing software on my computer but I have been seriously scared away from going any further in this editing process after reading on this forum just how difficult this is going to be with the kind of computer I have. So my question is HOW DIFFICULT IS THIS REALLY GOING TO BE?? Suppose I would want to make a 20 minute edited video with a few simple transitions and some titles and a basic audio music/narration track. I have a PC with an AMD Athlon64 3000+ CPU running at 1.8 GHZ, 3 Gigs of memory, Asus V9570 nVidia GFX 5700 128 MB graphics card and two internal Hard Disks @ 160 GB each. I have heard all sorts of horror stories that rendering a 20 minute AVCHD video will tie up my computer for hours and hours or even days to render such a project. Is this so? In short is it impractical to even consider editing in AVCHD with this computer settup. Along with now having to consider acquisition of a blue ray burner and player, do I really have to upgrade my whole computer package to something like quad core capability etc etc. Can I be a happy hobbyist working on AVCHD with my current computer or will it be like watching paint dry to do any editing projects. Any comments would be greatly welcomed. Specifics on how long it really takes to do these HD editing tasks would also be warmly welcomed.
Jeff Harper April 25th, 2009 01:37 PM
Use neo scene to convert the footage to 16:9 SD and your problems would be non-existent.
Stop recording in HD mode altogether and you would have no problems at all.
HD is nice. But people are obsessed with it. If you can live with SD just do that: quit shooting HD until you have a better computer and bluray burner.
If you cannot, then you must pay the price timewise and financially.
Lee Matheson May 1st, 2009 01:08 PM
Correction - VDPAU works great
Just a post to correct the quoted qualification. It turns out the problems I experienced with VDPAU on the BFG nVidia GeForce 8400 GS (512MB) PCI card were specific to an old PC. ...
VDPAU (and the playback of High Definition Videos) works great with this card on a different PC.
Specifically, I removed the BFG nVidia GeForce 8400GS PCI (512MB) graphic card out of the PC in which I was using it (an older (9+ years) athlon-1100 PC with an MSI KT3 ultra motherboard) where that PC was having the problems with the desktop.
I put the BFG nVidia GeForce 8400GS PCI (512MB) graphic card in my slightly newer athlon-2800 PC (+4 years old Asus A7N8X Deluxe motherboard ) and installed the proprietary nVidia driver (180.51) and KDE-3.5.10 w/openSUSE-11.1 works great. No corruption. vdpau works fabulous on this athlon-2800 with the 8400GS card.
I'm thinking now the problems I experienced on the athlon-1100 were PC specific, ... either
  • the power supply on the 9 year old PC was simply too old, or
  • there was a problem with interrupts, or
  • it was just a basic compatibility between the motherboard on that 9 year old PC and the graphic card.
So I am happy to report success on this and I can recommend the BFG nVidia GeForce 8400GS (PCI) card to PCs of the same vintage as my athlon-2800 ! It provides a High Definition Video playback capability that this old PC simply did not have before.
Bruce Foreman May 2nd, 2009 12:53 PM
Playback is one thing and editing is another.
One of the less demanding NLE's I use, PowerDirector 7 Ultra, specifies AMD Athlon 64 X2 5000+ as minimum for editing AVCHD. I had an HP with that processor, 3GB RAM, and the integrated Nvidia 6150LE graphics.
It would just barely "choke along" on the 1440x1080 clips and might possibly begin to handle a few 1920x1080 clips if I was willing to exercise a lot of patience and even try to work in very short segments.
I priced that computer to go fast and it did.
I have a Q6600 based machine with an Nvidia 8800GT 512MB card that does edit my stuff but shows signs of "dragging tail" when I need it to step along but it does do fairly well editing with PD7, for working with Pinnacle Studio 12 I have a Core i7 based machine coming.
Jeff's comment about folks being obsessed with HD is not necessarily true. Once one has seen their own HD content properly edited to their satisfaction and displayed on an HD large screen TV they are "hooked" but not necessarily "obsessed".
Almost all of what I produce to be distributed (training video for a Defensive Handgun class I teach or stuff for other family) is rendered to SD. But if it was shot in 1920x1080 and edited in HD before being burned in SD to regular DVD when played back it always seems to look noticeably better than the SD I used to shoot and produce.
And when you consider more and more folks are playing their DVD movies on upconverting DVD players hooked up to LCD and Plasma TV's it tends to look even better.
No obsession going on here and I understand some being reluctant to make the move into HD. It can be quite a financial shock not easily absorbed and if SD meets their needs and gives them what they want, that's fine. It's "content" that counts.
Neoscene conversion is helping some folks, but is not compatible with Pinnacle Studio (which while not most folks preference, is a very fully featured all in one NLE) and not needed in PowerDirector 7 Ultra, both of which edit AVCHD natively.
Things are sure changing fast and no matter what you get your hands on it is obsoleting as you get it.
Lee Matheson May 2nd, 2009 04:46 PM
Old vs new computers
Indeed. ... although of course both are important.
On my old athlon-1100 w/1GB RAM and a nVidia MX440 (ie no vdapu and no pure-video) running openSUSE-11.1 Linux (KDE-3.5.10), I can not play any HD videos with any sort of real time speed. BUT I can edit them with the Linux program kdenlive. And I can render them (albeit it is VERY slow). Now the editing is not "precise" to the frame (because of the noted problem with HD playback) but it can be done, and the athlon-1100 can then encode and output HD videos (that take forever to encode). Of course, the athlon-1100 can not play its own videos properly after they are output.
My experience is I spend more time picking videos, and moving them about on the time line, and adding transitions, than I do encoding. If encoding is slow, I can always do something else.
The point? Well, the point is with the right software, even old PCs can use an NLE and encode. Its slow. Very slow. But they can encode (with the right software). But they can't play at any sort of realistic speed without the hardware.
I currently do most my NLE editing (in Linux with kdenlive) on a relatively new laptop, which has an Intel Core2 duo P8400 cpu (4GB RAM and a Radeon 3450 graphic card). I do it on that laptop because my Athlon-2800 , while it can encode (and with the nVidia 8400 GS card playback even better) is still very slow at encoding. Very slow. The Intel Core2 duo P8400 is much faster.
But even that is not fast enough for me, and I have ordered a new Intel i7 Core based PC (desktop) that I plan to use for my AVCHD. It will hopefully be just that much faster in editing. The speed of new hardware is always nice.
There is work ongoing with video software in Linux (and I would be surprised if this were not also the case in Windows) to enable NLE (such as kdenlive) to use the GPU available decoding in graphic cards (such as vdapu) to indirectly improve the editing speed. Ideas are to improve the speed of the timeline presentations (where decoding is needed) .... That capability is not there yet (as it is desired to be able to do this to the frame level), ... it is being worked on, and if it is obtained, then old PCs (such as my athlon-2800 with its 8400GS card) will have a new lease in life (with increased editing speed) when it comes to NLE (and not just in playback). ...
Speaking of which, testing today proved my athlon-2800 w/nvidia 8400GS and vdpau can play back better (h.264, mpeg1/2, and .wmv videos) than the Intel Core2 duo P8400 with radeon 3450. Thats all because of the offloading of the video to the graphic card GPU. Its truely "a thing of beauty" to see an old PC perform so much better than a newer PC which should be 3x faster (but in this case, is not).
BUT, overall, I think I agree with your views. I happen to think older PCs can be made to work with HD videos, and the capability of older PCs to edit HD may actually improve with time (with new software taking advantage of offloading to the GPU) ... BUT, ... despite all of that, it still is no substitute for the speed and easier edits that one gets with brand new state of the art hardware.
When I get my new Core i7 up and running with openSUSE-11.1, I'll post as to the success (or failure) of my NLE efforts. Based on what I've seen with my athlon-2800 (w/8400GS) and my Intel Core P8400, I'm pretty optimistic.
P.S. Just a note - the above is all based on Linux experience. I don't do windows (not since 1998).
Bruce Foreman May 6th, 2009 05:56 PM
I got my Dell XPS Studio 435 Core i7 920 based computer a couple of days ago. Makes me want to kick everything else out the door.
All I've had a chance to try so far is editing some AVCHD that brought my Q6600 quad core to it's knees, with the new box it went smooth real smooth. The OS is Vista Home Premium 64bit and so far everything looks stable.
Lee Matheson May 10th, 2009 06:52 AM
My Intel Core i7 also arrived
I know what you mean. My Intel Core i7 arrived on Tuesday last week ... its a custom built Asus P6T Deluxe V2 with the Intel Core i7 CPU, 6 GB RAM, nVidia GTX 260, and 1.5 TB hard drive. It simply "smokes" in terms of speed. Very nice.
I've rendered some videos with it with openSUSE-11.1 Linux programs avidemux, xvidenc and h264enc, and it was fast. Especially h264enc and it makes me wonder if Intel put microcode in the Core i7 to speed up h.264 encoding? ... Anyway, I have yet to try out a NLE with it. I'm currently creating some panorama shots with it (stitching various images together) and hope to get around to testing my favourite Linux NLE (kdenlive) later this week.
Lee Matheson June 11th, 2009 02:56 PM
Editing Canon HF S10 clips w/kdenlive on Intel Core i7 920
I've been using kdenlive (with openSUSE Linux) with video clips from my new Canon HF S10. kdenlive is "hit and miss" when it comes to handling that resolution. A recent update to mlt and kdenlive helped a bit but they are not quite there yet. If I move back and forth in the video preview, it will sometimes shows up corrupted and I can NOT select a specific frame (at the 1920x1280 @ the Canon's highest bit rate). Hence for the time being, I find it best to reduce the video from 1920x1080 to 1280x720 8000 KBits/sec resolution and that edits easily with kdenlive. Note this is simply a hiccup in kdenlive (or one of its dependencies) in handling this high resolution/high bit rate. My Intel Core i7 920 based PC has lots of horsepower and memory to handle this high resolution bit rate.
So for my openSUSE-11.1 PC (KDE-3.5.10), I use the ffmpeg command:
Code:
ffmpeg -y -i 00017.mts -f avi -vcodec mpeg4 -b 8000000 -acodec ac3 -ab 128000 -s 1280x720 17.avi
I also purchased a monopod and it helps significantly in reducing the video jitter. Its not as good as a tripod, but I confess I hate (refuse to) carrying a tripod. But a monopod is doable and the videos are nice!! I'm still struggling a bit to find a good site to host the 1280x720 resolution videos.
I'm heading off to South East Asia on vacation in 4 days. Hopefully I'll get some good videos.
Also - as an aside - my ancient (5+ year old) 32-bit athlon-2800 with 2GB RAM (and a PCI bus (not PCI-e) nVidia 8400GS graphic card) can play the raw 1920x1080 @ the Canon HF S10's highest bit rate video clips with no problem using nVidia vdpau (Linux Pure Video equivalent) technology, at about 15% cpu loading. ie all the video decoding is effectively off loaded to the nVidia 8400GS Graphic Processor Unit (GPU).
