-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   external harddrive question please help (https://www.dvinfo.net/forum/non-linear-editing-pc/19741-external-harddrive-question-please-help.html)
Patrick Falls January 13th, 2004 12:42 PM
i have a western digital 160 gig usb 2.0 7200rpm running on windows xp and it does not let me drag and drop huge files to it. i try and drag 4 gig video files into it and it says " cannot copy there isn't enough disk space try running disk clean up ".
is there a setting in xp where i can manage large file transfers from drive to drive?
will i get what i'm looking for in a firewire external drive?
i also tried to partition it into an NTFS drive but after i completed all of the steps in partition magic, rebooted my machine it gave me an error, and remained a FAT32 drive.
Michael Wisniewski January 13th, 2004 12:50 PM
You need to format the drive with NTFS. FAT32 doesn't support files over 2GB - that's why you can't drag the files over.
Use Windows XP to convert it to NTFS.
Open the:
- Control Panel
-- Administrative Tools
--- Computer Management
Click on Disk Management, it should be under the Storage section
Right-click the drive and Format as an NTFS drive
Patrick Falls January 13th, 2004 01:19 PM
cool
what should i put for allocation unit size? it gives me choices from 64k up to 8192.
i do need to enable file and folder compression right?
Michael Wisniewski January 13th, 2004 06:56 PM
Use the defaults settings when formatting. For most purposes though, any setting will work.
I wouldn't recommend using file and folder compression - it will make your hard disk and CPU work overtime.
Patrick Falls January 13th, 2004 08:27 PM
whoa
i'm happy i waited, i was going to select the compression box. thanks a million.
Glenn Chan January 13th, 2004 08:30 PM
I doubt Windows would squeeze much compression out of DV files.
