-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   HD30000U D-VHD deck computer install help (https://www.dvinfo.net/forum/non-linear-editing-pc/26743-hd30000u-d-vhd-deck-computer-install-help.html)
Dwight Flynn May 29th, 2004 11:07 AM
I have the DH30000U D-vhs deck and I am planning to use it with my firewire card on my computer, along with my hd10u. I noticed when I pluged the firewire cable into the deck from the computer the plug-and-play installation stops at hardware wizard looking for av/c tuner. Does this unit not install and can it not be controlled by a computer. If it can then am I missing a driver or some other software. I have a athlon64 using widows xp home. HELP.
Ed Smith May 30th, 2004 07:51 AM
Dwight,
Normally you do not need to install any drivers for decks/camcorders etc. Windows XP normally installs it automatically. What happens if you click cancel on the hardware installation, does it still install? Was there any CD supplied with your deck?
I am not familar with your model of deck.
Cheers,
Dwight Flynn June 1st, 2004 11:40 AM
Ed, when I stop the hardware install xp says it has not been properly installed. It did not come with a CD and JVC says that although they know it can be controlled by firewire on a computer it was not necessarily designed for that purpose.
