Hi,
Not much to add, Rob has said it all! Just a quick note on hardware RAID 5. I'm currently using a PCI card: Promise S150 SX4 SATA. It is a 4 channel raid card with hardware XOR machine + you can have up to 256mb of memory onboard. This card costs about 1800:- SEK ( should be about £150 or 260$ ). You can start with 3 drives and then expand the array later. It also support RAID 0,1,10 etc - lots of bang for the buck. Since you're having all this trouble with an _external_ drive, I belive in on of these explanations: 1. Bad/wrong chipset drivers for your motherboard 2. No FAN inside enclosure 3. Faulty drive HD Tach reporting zero after a while indicates causes 3 or 1. Good luck! // Lazze \\ ps. Rob, do you have a extra speedy keyboard? You write so looong posts :-) ds. |
I have to agree with Lazze, ehrm, yeah, okay <g>
Dunno 'bout the keyboard, it came with my Dell laptop, eheh. But I can pretty much type blind, so that should help! |
Nobody here has mentioned firewire 800 hard drives and controllers.
The contoller cards go for around $69, and the firewire 800 drives are coming as large as 400-500 gigs, at a little less than a dollar a gig. I've been looking at them for some time now, and the throughput seems to be more than fast enough for DV editing. Have people had problems with these? Thanks, Jeff P |
The reason I didn't mention those (they go to 400 - 500 gig by
using two drives in a raid 0 setup [striping]) was that John was looking for more security (ie raid 1 or 5) which is very hard to do with an external setup. But thanks for pointing those out! |
| All times are GMT -6. The time now is 04:05 AM. |
