-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Placing Still Images into Widescreen PAL Video for Time Lapse (https://www.dvinfo.net/forum/non-linear-editing-pc/58857-placing-still-images-into-widescreen-pal-video-time-lapse.html)
James Darren January 22nd, 2006 01:21 AM
G'day all,
I'm going to be doing some time lapse photography with my Canon Digital SLR & have a few questions on how to achieve this....
Some quick info:
-Using Canon 300D/Rebel Digital SLR
-Photoshop CS2 & Adode Premiere v7.0
-PAL 16:9 Widescreen will be the output
1: Do I set my camera colour space to Adobe RGB or sRGB?
2: Is it best to set the image size in the camera to Large Jpeg 3072 x 2048 or Medium Jpeg 2048 x 1360? Both resolutions should be enough even if I do HD time lapses later on but is there any benefit when resizing in Photoshop?
3: Obviously I need to crop & change the aspect ratio of the images I shoot later on in post. Is it easier to crop the centre out of the SLR image or cropping only the bottom or only the top? In other words, how should frame my camera when shooting so its easier to crop in Photoshop later?
3: Now I need to set up a action in Photoshop to resize, crop etc the images. I'll obviously need to change the actual size & aspect ratio as the SLR images are 1.5:1 whereas I need 1.77:1 (16:9). How do i do all this? Do I create 1024 x 576 iomages in Photoshop or do I create a 720 x 576 using the different pixel aspect ratio for PAL widescreen?
4: Do I need to change any of the displayed colours since its being outputted to PAL TV? I believe there are 0-256 colours but TV only shows 7-?. Is this true for PAL or only NTSC?
Well hopefully that should cover it, once I have the images cropped, resized, etc I should be able handle the rest myself in Premiere.
Any help or advice will be appreciated....
James Darren January 24th, 2006 09:24 AM
anyone?...
Emre Safak January 24th, 2006 02:16 PM
G'day to you, too!
1. Use RAW and output to the PAL/SECAM color space in ACR.
2. Either way you have much more information than you need (for DV). Personally I would just shoot RAW.
3a. It's better to use the centre as that is where the lens is sharpest.
3b. I don't know how Premiere handles pixel aspect ratio, but you can help yourself by reading the "Saving images for use in video" section in the CS2 help file. Plus there are actions for converting files for use in video! Just go to the Actions tab and click on the little arrow. At the bottom of the list you should see the "Video Actions" set.
4. You took care of that in step one. For NTSC you would convert to the NTSC color space.
