-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Optimal external drive for lap top as main scratch disk (https://www.dvinfo.net/forum/non-linear-editing-pc/89001-optimal-external-drive-lap-top-main-scratch-disk.html)
Michael Barrette March 15th, 2007 11:38 AM
Ok, I really want to understand the optimal drive and way of working with an external hard drive as your main scratch disk when editing with a lap top.
I took the risk and bought a new high end lap top as my video editor and I will be doing quite a bit of HDV editing. One of the drawbacks is a 5400rpm hard drive. I can buy a 7200 mobile drive for it, but they are not nearly as big as the external ones.
So here are my questions:
1) The options here are eSata or firewire if we want to keep up the speed of the machine right? USB just won't cut it. How about eSATA, is that just as fast as an internal drive? or will it be slower, and my 5400 rpm (fastest 5400 on the market), will remain as fast as a firewired or eSATA'd 7200 rpm?
2) I don't understand the workflow very well here. If I am using an external drive as my capture and export drive, then how do I hook it up to both my computer and my camera at the same time? Is this possible? Otherwise, I guess this external drive is only good for editing for DVD or web, and not for exporting to tape? That's a major drawback. Comments on this?
3) So what's an exact external drive that anyone suggest that works for them?
Thanks for any help here!!!
Cheers,
Michael
Harm Millaard March 15th, 2007 01:24 PM
I answered this question in your previous thread.
Trond Saetre March 15th, 2007 02:39 PM
Michael, I use a laptop (Dell XPS M1710) with a 500GB Western Digital external (USB) drive for editing. So far I am only editing SD, and it works flawless. You should not have any problems with SD export to tape.
(To view HDV video from the external harddrive also works fine for me.)
Steven Davis March 15th, 2007 02:41 PM
Look into the Icy Dock external hot swappaple enclosures. I've been very happy with the unit, and thier customer service is better than anything I have every seen.
And yes, better than Sony.......................pause.............yep, that's a joke.
Harm Millaard March 15th, 2007 02:56 PM
Are you happy with the crippled performance? A USB drive achieves possibly a 20-25 MB transfer rate with a 12% CPU load and often far less than that, in comparison to an eSATA drive that manages 60-75 MB/s transfer rate with a 1-2% CPU load. If you share USB devices (meaning you use more than one) the bus will be shared and your transfer rates will drop significantly.
Michael Barrette March 15th, 2007 03:31 PM
Hi Harm,
Yes, thanks for the other reply. It does appear eSATA with card attachment to lap top is the way to go, and dang cheap to! Only $50 canadian and I got myself the set up which is supposed to be just as fast as putting the hard drive in a tower... Sweet.
Now the last drawback of the laptop... 2GB of RAM on Vista is not really enough for an HDV system and 2GB sticks are pretty steeply priced... other than that, I'm sittin pretty (except last thing, premiere seems to be very finicky meaning I waste hours of my time with stupid problems, so vegas is starting to look appealing). Thanks for the help.
Michael
Michael Barrette March 15th, 2007 03:34 PM
Steven,
That icy dock looks pretty sweet if you require a few hard drives. For portability sake and because I only need one here to get going, the eSATA card drive is going to do the trick.
cheers,
Michael
Shahab Malik March 15th, 2007 04:07 PM
Workflow
I use an external Maxtor Firewire drive, 500GB. My laptop connects directly to the External drive, and then the External drive has another firewire port that connects to my DV camera (Daisy Chain). It works great.
Trond Saetre March 15th, 2007 05:43 PM
Yes, with SD video I have never had any problems at all using an USB external harddrive.
Merton Gaudette March 15th, 2007 06:23 PM
Thank you Shahab
OK..now..I think I'm beginning to understand how this works. So I connect an External Firewire HD to my Laptop and connect the camera to the HD. So I can capture *and* edit SDV on the External HD? Hmmm...do I install editing software to the External HD?
Michael Barrette March 15th, 2007 08:59 PM
Now that's service.
I had really no idea what to do about the external hard drive thing around midnight last night and posted on this forum, and I already had enough answers I went out and purchased my 500GB drive and the eSATA stuff required. Turns out it was about $110 for the eSata set up as it requires a Card Bus to attach to computer. Pretty sweet set up for HDV.
I am not sure if a firewire 800 would have done the trick or not. Would have been about half price. From the post above, it does sound like it's really easy to hook camera up to the ext. drive and have it daisy chained to computer. That's not a bad set up. Probably fast enough for HDV? considering that's how the video's going into the computer in the first place... but the eSATA is JUST as fast as having the drive in a tower, so that's really sweet.
As for the question about editing software, you just have that on your main computer. Your external drive is just used as your video drive, your scratch drive. Your computer just acts like it's another hard drive for storage space.
Cheers,
Michael
Harm Millaard March 16th, 2007 03:18 AM
Michael,
Just one more remark. You mentioned the 2 GB Ram limitation and you mentioned Vista. Why not keep using WinXP Pro for the time being? That would not put as much of a drain on system resources as Vista does, you would have proven drivers for all your components and it is faster than Vista.
John Miller March 16th, 2007 07:55 AM
I recently ran some benchmarks on one of our applications and tested external USB 2.0 drives vs. FireWire.
There was no measureable difference between using the drives via USB 2.0 and FireWire.
Using external FireWire drives daisy-chained with a camcorder can lead to a drop in performance for the drive.
I prefer to use the USB interface for the hard drives and leave the FireWire ports for the video devices.
(Note, this is in the context of 25Mbps DV).
Harm Millaard March 16th, 2007 09:40 AM
John,
From my experience I have to disagree with you. A simple benchmark using the same external disk, a Maxtor Onetouch 250, shows (at least on my system and with the same amount of data on it that with:
1. USB2 the average transfer rate is around 20 MB/s and CPU load is 12.6%
2. 1394 the average transfer rate is around 27 MB/s and CPU load is 1.4%
This was performed with the same disk, once connected by USB2 and once by 1394. No files were added or removed between the tests. The tests were run several times (5 times each) and the averages were as mentioned above, using the Canopus DVStorm HDTest.
John Miller March 16th, 2007 09:56 AM
I think you have to distinguish between tests that use the disk access and data transfer as the rate limiting step and those that are part of a more realistic application.
For applications that perform a lot of computation on data, the data transfer rate to and from the hard drive is less important.
I think the contrasting views and experiences all given in this thread demonstrate that "mileage will vary" according to the user's particular application.
Michael Barrette March 16th, 2007 12:11 PM
I am guessing capturing on firewire and interfacing with computer by USB is perfectly fine for the capture process. Then, while rendering and editing, you'd probably want to go back to the firewire to computer... just a guess.
As for VISTA, my lap top came with it, but yes, I am definitely thinking of going back to XP. Vista is a little more fancy visually and I do like the explore functions etc. but overall there is really no reason why I should take up 60% of a one gig chip just to run my system...
cheers,
Michael
Harm Millaard March 16th, 2007 01:43 PM
John,
What tests did you use?
If you consider transfer rates for NLE work not overly important, what are the measures that do impact performance in your opinion? AFAIK transfer rates are the MOST important measure for NLE, not sound level or idle power consumption.
John Miller March 21st, 2007 04:43 PM
Sorry for not replying sooner - I've just seen this (!)
I used our DV processing software to do burn timecode, convert aspect ratio and some color correction on a DV AVI file, writing the processed version to a new file on a separate drive. (i.e., I had two drives - for the FireWire case, I used two separate interfaces - one on the mobo, another on a PCI card).
Basically, I ran the process once with both drives connected via FireWire and then repeated it with both connected via USB2.0. The difference in overall processing time was about 1%. The total time for the processing was about 125 seconds. Without any processing - effectively just a straight copy but using the DirectShow infrastructure - the time was about 70 seconds. A direct file copy via Windows Explorer took about 40 seconds. I have to say I expected to see a significant difference but was pleasantly surprised that using USB2.0 did not seem to have a negative impact.
When I get a chance, I'll run some simple comparisons using GraphEdit - basically, copy one DV AVI to another using FireWire and then USB2.0. I'll compare those times to the direct copy via Explorer.
