-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Blue Screen Code - BAD_POOL_HEADER? (https://www.dvinfo.net/forum/non-linear-editing-pc/98467-blue-screen-code-bad_pool_header.html)
James Emory July 8th, 2007 07:21 PM
It's very rare, especially considering the amount of work my laptop performs without incident, but I experienced a blue screen event the other night and the code that was displayed said BAD_POOL_HEADER. Everything has worked just fine since then, as it always has after a blue screen event. What does that code mean?
Ed Smith July 9th, 2007 06:34 AM
A quick scan on google found this link:
http://www.tweaksforgeeks.com/BAD_POOL_HEADER.html
Normally there are other numbers displayed after the message in the blue screen - these are more descriptive than the heading.
Usually windows reports blue screens to the event log, so a quick check of the system/ application log should tell you the whole string. Then a simple search in google should tell you what it means.
cheers,
James Emory July 10th, 2007 08:21 PM
Thanks for that info Ed. I guess I'll just Google the codes from now on since Microsoft doesn't seem to have a list with definitions readily available.
