-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Wide-angle lens question (https://www.dvinfo.net/forum/open-dv-discussion/10272-wide-angle-lens-question.html)
Charles Papert June 1st, 2003 04:28 PM
<<<-- Originally posted by Jeff Donald : I believe Tiffen is still in Chapter 11 Bankruptcy. Delivery from Tiffen has always been slow and inventory levels spotty, but the Chapter 11 just makes matters worse. I've not heard how their reorganizing efforts are coming. -->>>
Talking with the Steadicam sales folk at NAB a few months ago, Tiffen is coming out of it slow but sure. Who knows what the real deal is tho'.
Srinivasa Yerneni June 2nd, 2003 04:06 PM
Wide angle lens + filter
Hi all, Thanks for the input and suggestions.
Looks like Tiffen Mega Plus 0.56x is the way to go as its
in my price range(~$75).
Tiffen Mega Plus 0.56x uses a 72mm front thread.
Is it good to use filter after the wide-angle lens OR
in between camera lens and wide angle lens ??
The reason is 37mm filters are chaper than 72mm filters.
Also, Can I cascade the filters (2 filters at the same time) ?
Thanks again.
Alex Knappenberger June 2nd, 2003 04:12 PM
If you put them between the WA lens and the camera, that will place the lens further away from the camera, thus increasing the chance for vignette. If you put them on the WA lens, that might also cause vignette too, depending on how wide the lens is. Either way, if your going to put a filter on, don't put it between the camera and the lens. Stacking 2 would be fine, but once again, you might get some vignette.
