First question here about a rock concert movie
Hi everyone on this forum. Im new here.
Im a screenwriter and editor. But now I got a work to do a concert movie for a swedish band. So I have some questions for this. My influence for this is the U2 - Rattle and hum, and also some Anton Corbijn work. I was thinking to work with five cameras, with mini35 and HD-100. Here I wonder if I should use DV or HDV? What I want is the depth of field, just like they have in the concerts I mentioned above. So my first thread is if anyone have any advice about this. What do you think. Is it overkill to use mini35 for a concert movie? I also want to say that - i will not be one of the photographer - im just want to know more as adirector. |
Bear in mind the fact that the HD100 is not great at low light levels, and the Mini 35 will reduce that even more (and rock concert lighting is not always ideal for video). The setup would be quite bulky so you would probably be restricted to static tripod shots rather than roving cameras, and you may have to have two man crews on each camera (one operator, one focus puller, with maybe a seperate HD monitor). Also, if you're not too close to the stage you will need long lenses, which will cut down on the light even more. HD100's can't be genlocked together so you might want to consider HD250's instead
Thanks for your answer.
The concert place is rather small so I think we can have the cameras near the stage. If we only have static tripod shots, do you think we should even then must have two men on every camera? How many steps do the mini 35 takes? I heard two steps - is that right? So if you should do a concert movie - what should you have for equipment if you want a more "film look" a more Anton Corbijn style? |
Arvid,
Shallow depth of field is primarily a function of aperature size. The larger the aperature, all other things being equal, the shallower your depth of field will be. Stage lighting tends to be very BRIGHT, particularly spotlights and performer key lights. So to get a proper exposure, your camera will want to shut DOWN the aperature, and you'll get a much broader depth of field Things that can help: Controlling the stage lighting so it's bright enough but not TOO bright. Using cameras with good lenses and larger primary sensors (more pro then consumer) which gather light more efficiently so you can increase your shutter speed or kick in a ND filter, lowering the amount of light gathering and allowing you to open your aperature further. Using external neutral density filters on the camera - again allowing the aperature to open up. Shooting from farther away, and at longer zoom settings - again, diminishing the light hitting the sensor and, again, allowing a wider aperature to get a proper exposure. But be careful with all of these. At some point, if you don't have enough light hitting the sensor for a proper exposure, you'll be fighting sensor noise. Just a few ideas. Good luck. |
Hi And thanks for your comments.
Do you have any suggestions about which camera i should choice. One person recommended AG-DVX100 progressive One other HD-100 And a third AG-HVX200 The last one Iīm little afraid of because of the P2 cards, and we will shot the concerts two nights with five cameras so it will be plenty administration for the photographers. If I have a bigger budget I maybe should choice a IMX camera and Pro35 but i dont think I got that money fr this production. Do anyone know U2īs Rattle and hum DVD - I want something like that. Or Anton Corbijnīs Depeche Mode DVD - Devotion. Is it totally wrong or even stupid to even think about to use mini 35? |
BTW, have you watched The Last Waltz?
I could be wrong but I think that's considered the cream of the crop in concert films. It's directed by Scorsese and has people like Lazlo Kovacs as cameraman. In fact, all of the camera operators were superb DPs in their own right. It was shot on 35mm. The Muddy Waters performance is fantastic but Scorsese thought that he wasn't performing so all of the camera operators were changing film in their camera except for Kovacs - Kovacs shoots the whole thing with one camera and keeps it interesting. It's a good lesson in what to do in an emergency.
Have fun. I love shooting live performances. You never know quite what you'll be confronted with. |
Rattle & Hum was shot on 16mm. You could always shot some Super 8mm footage, that would look cool. Good advice by Bill about the lighting. Contrast can also be an issue. I shot a concert performance where the contrast range between the lead singer and the bass player was too much. I chose to keep the lead singer looking normally exposed, which put the bass player in a well of darkness. I'd recommend telling band members if they are not standing in on a part of the stage that is lit, they probably will be too dark.
For me its ok if some part of the picture is black. But of course not always. |
But have anyone some more comments about my choice or thinking to use a mini 35 for the concert.
Is that a bad choice - should I rethink. What do you say. |
bert,
As a director/dp of a fair amount of concert video, and former hd100 owner with mini35 experience, I can tell you you're not going to have enough light for this. The hd100 mini combo is about 150 ASA. Youll be amost 2 stops under. Btw, the concert stuff in R&H was 35 and the doc stuff was 16. You can see the 35Bls clearly in multiple places |
So do I understand all of you so should I rethink my idea to use mini 35.
Please give me a helping hand on this. About the light, i will have a person on that so he can give the stage more light if I need to. |
You would need a number of lights so large it would be impractical, most likely. Just adding a few par64s is not going to fix it.
Ok thanks.
So if I dont use mini35 - should I then use IMX Cameras so i can do more fix in the postproduktion? |
Thanks for all help.
I think im going to use IMX. |
| All times are GMT -6. The time now is 09:34 AM. |
