NTSC to PAL
this question may of been asked many times before, yet what is the best method in converting 30p footage to 24p to print to film?
Is there specific software or methos in doing do... Also i assume this method would suffice in converting NTSC to PAL?? Thanks in advanced to anyone who knows... |
i've been doing this in vegas 4 by re-rendering out to PAL/24fps and setting resample on. seems to be working....no flicker I can see.
but then...i've never printed to film. |
bill..
i have vegas video 4 but never had used it.. by resampling, are you refering to the method of "force resampling" ...to export PAL is it under the settings in the file save window?? im under the impression that the DV PAL setting is a built in compressor, let alone a method to change NTSC to PAL.. am i correct?? is there any other way just to change frame rate to 25P? |
| All times are GMT -6. The time now is 09:47 PM. |
