Manfrotto 503hdv head problem... help!!
Hi, i was wandering if anyone else with a Manfrotto 503HDV head had this problem, i find that if i put the drag up to full on the tilt, it has very low drag, it hardly has any resistance and it is very hard to make moves with it because it is to easy to move. The pan is absolutely fine and gives very good resitance.
I was just wandering if anyone knew if this was common with all the 503's or just mine thanks in advance for your help |
Hi Sam.............
| All times are GMT -6. The time now is 08:34 AM. |
