-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   EXI SDI Output (https://www.dvinfo.net/forum/open-dv-discussion/124159-exi-sdi-output.html)
Roger Dowling June 20th, 2008 07:12 AM
EXI SDI Output
Can anyone please confirm if this output supplies 4:2:2 colour signal.
Also is this an uncompressed signal.
Dan Keaton June 20th, 2008 07:15 AM
Dear Roger,
The HD-SDI output of the Sony EX1 is a 4:2:2 10-bit signal.
This is what is commonly called an "uncompressed" signal as it has not gone through MPEG2 compression.
Roger Dowling June 20th, 2008 07:29 AM
Thanks Dan,
Adjusting to the EX1 is taking some time.
So using the SDI output for direct recording via a Nano HD unit should provide excellent quality?
Roger Dowling
South Australia.
Dan Keaton June 20th, 2008 07:33 AM
Dear Roger,
The HD-SDI output provides the highest quality signal that you can obtain from the Sony EX1.
Yours is a very good camera that produces outstanding images.
Yes, you can record to Convergent-Design's nanoFlash or Flash XDR in order to achieve the highest quality that your camera can produce.
In addition to Convergent-Design's products, there are other ways of recording a HD-SDI signal.
Ray Bell June 20th, 2008 07:51 AM
Here you go...
http://dvinfo.net/conf/showthread.ph...758#post895758
