-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   iSight modification 6 to 4Pin+Power = DV Camera (https://www.dvinfo.net/forum/open-dv-discussion/19317-isight-modification-6-4pin-power-dv-camera.html)
Brian Broz January 5th, 2004 08:55 PM
Hi,
I was wondering if any has/knows how to modify an iSight to use as a "lipstick" or "helmet cam"...to record into a DV camera's firewire in.
DV cameras are all 4 pin and the iSight is 6pin...a 4-6Pin adaptor should work for everything but power...
Does anyone have any ideas how to do this? Does it run off 12V or 7.2V??
Thanks very much!
Brian Broz
John Gaspain January 6th, 2004 09:20 AM
It would be cool!, btw how many lines of resolution? 480?
You might want to check out http://www.jonescam.tv/ for a good helmet cam
Rob Hester January 7th, 2004 08:21 AM
this would be really cool! someone's gotta have hte know how
Bill Pryor January 7th, 2004 01:00 PM
The bigger 6 pin firewire connector is what professional cameras use, as well as lots of computers like the Mac G4's and 5's. You can get a 6-pin to 4-pin firewire cable at any Radio Shack.
Brian Broz January 7th, 2004 01:12 PM
But the issue is power. The iSight (6Pin) requires a power source.
I'm just going with a www.rushcam.com
More rugged, anyways!
Brian
Bill Pryor January 7th, 2004 01:22 PM
Oh, OK, I missed that part about power. I thought you just needed firewire to firewire.
Brian T. Young January 7th, 2004 10:17 PM
check out helmetcamera.com
looks interesting
Rob Lohman January 8th, 2004 12:40 PM
It looks like the power on an USB bus is 5V (pin 1 + pin 4 ground
I think)
